Thread: Anyone recomend a checklist for over 100k miles?
Results 1 to 5 of 5
chrisatpsu Anyone recomend a checklist... 05-20-2012, 10:45 PM
txslow6 Re: Anyone recomend a... 05-20-2012, 11:13 PM
bps02gtp Re: Anyone recomend a... 05-21-2012, 12:40 AM
MoarkatsINmuhtrailer Charging system test. Air... 05-21-2012, 01:22 AM
TexasTanker19kilo20 Re: Anyone recomend a... 05-21-2012, 01:35 AM
  1. #1 Anyone recomend a checklist for over 100k miles?
    May 2012
    Indiana, PA
    recently bought a 2000 GP GTP
    after changing the sparkplugs, i can see that regular maintenance hasn't been performed for this car anywhere near recently.
    can anybody come up with a good checklist of things to watch for, check, or replace on the car? sorta like my own multi point inspection.
    2000 Grand Prix GTP Sedan
    110k miles
  2. #2 Re: Anyone recomend a checklist for over 100k miles?
    Texas
    Check oil/trans pan for leaks.
    Fuel filter
    fuel injection cleaning
    Gasket check
    plastic vaccum lines replaced with rubber
    sway bar end links
    smell trans fluid
    Check power steering pump
    check CV
    check trailoring arms
    check struts and springs
    alignment good?
    Check belts
    That should get you started. I'm sure I'm missing some.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: Anyone recomend a checklist for over 100k miles?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    might as well replace the trans filter
    coolant flush
    some ppl like to change brake fluid
    air filter?
    definately the famous LIM gasket check and replace which goes along with the already mentioned gasket check.
    txslow did a good job mentioning what should be replaced and what should be checked. just do that and u'll be good to go.
    Ohio
    Air conditioning (if you want)
    Belts (dry rotted/cracked)
    Coolant elbows
    Clean coil pack terminals (light sandpaper to rod of any and all corrosion)
    Supercharger coupler (sounds like rocks jumping around when being revved)
    Brakes
    Power steering fluid
  5. #5 Re: Anyone recomend a checklist for over 100k miles?
    Sep 2011
    Copperas Cove, TEXAS
    Helps if you change the SC oil also, it's easy to do.
  1. Suspension overhaul checklist
    By RareGMFan in forum Brakes/Suspension/Chassis
    Last Post: 12-02-2010, 10:58 AM
  2. what helmet do you recomend for drag racing?
    By AmericanSoldier in forum Off Topic Discussion
    Last Post: 10-15-2010, 06:34 PM
  3. new pistons: going down the checklist
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 05:37 PM
  4. If i was to get 20" rims how wide would you recomend with out rub?
    By MattTheBaker123 in forum Tires & Wheels
    Last Post: 10-24-2009, 06:07 PM
  5. What kind of rims would you recomend on my gp with this color
    Last Post: 07-30-2009, 12:05 PM
