Thread: Heater Hose Problems
Results 1 to 13 of 13
  1. #1 Heater Hose Problems
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    I've had the heater hoses (90 degree plastic hose for radiator fluid) replaced on my GTP a couple times, we tried the AutoZone type then did a GM type and still they continue to bust/crack/break. My mechanic thought he saw a metal version of them somewhere so I was wondering if anyone has seen this and where to buy them to speed up the repair time. Any help would be wonderful or any other suggestions on how to keep these damn things from breaking. Thanks!!
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #2 Re: Heater Hose Problems
    St. Louis
    If you are referring to the coolant elbows, then no. I've not seen a metal set. There was talk of someone making them but I've yet to see a set made. If they keep leaking then it sounds like they are being installed wrong. I've had no issues from the Dorman brand ones that are in the "Help" section of autozone and the like. Just lube the orings on them and then make sure they are going in squarely as you tighten the tensioner assembly. If you get it in there slightly off then it will leak again soon.
  3. #3 Re: Heater Hose Problems
    Dorman actually did report a problem with their manufacturing line on the elbows a while back and they do stand behind their lifetime warranty.
    Something to consider though. These should be installed in clean (no ridges from the previous elbow) tensioner/lim/timing cover holes. Using a lubricant on the o-rings. I prefer vasoline (cheap and in the toolbox) or oil. When tightening the tensioner to the head of the motor, wiggle the top elbow to ensure it does not get bound. Even when the bolts are fully tightened, it should have a little play. If that doesn't happen the elbow tends to deform with heat and leak.
  4. #4 Re: Heater Hose Problems
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Even putting a little coolant on the oring lubricates well. Doesn't take much. If its not sliding in there fairly easy then u have possibly a broken piece in there still
  5. #5 Re: Heater Hose Problems
    Nov 2009
    - Aluminum Coolant Elbows #
    Looks like ZZP started making them!!!
  6. #6 Re: Heater Hose Problems
    Nov 2009
    Has anyone used these yet? I'm thinking about buying some just so I have them already for the next time my coolant elbows die.
  7. #7 Re: Heater Hose Problems
    SE Level Member joelee669's Avatar
    Jan 2012
    manville, nj 08835
    make sure you are getting that old o ring out they like to get stuck in the lim and then the new one can't go in all the way
  8. #8 Re: Heater Hose Problems
    Nov 2009
    I will next time they need to be changed out. Anyone have any opinions on the ZZP metal collant elbows? I'm sure there are some pros/cons to them and I'd love to know some of them before I go out and buy these.
  9. #9 Re: Heater Hose Problems
    Quote Originally Posted by UCF04GPGTPCompG View Post
    You post in a 5 month old thread and then think ZZP did something? LOL hahahahahhahaha
    Rockauto.com search part 47065HP. Yeah
  10. #10 Re: Heater Hose Problems
    Nov 2009
    I'm pretty sure I never said that they did anything because of what I said. I'm just noting that when I first made this post no one knew of a company that made metal ones. I looked on the ZZP website randomly yesterday and noticed they were there. Besides, kinda late for you to come in now and say "some one else has been doing this" if you knew that should have said something then.
  11. #11 Re: Heater Hose Problems
  12. #12 Re: Heater Hose Problems
    Nov 2009
    ZZP to my door: $20.60
    RockAuto to my door: $22.52
  13. #13 Re: Heater Hose Problems
    Nov 2009
    From 2 weeks ago, ok. So is it just me or does it seem like it's a new part then? Or have all of us really not seen it for that long?
  1. Which one is heater inlet hose?
    By fuzzbutt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2013, 10:16 PM
  2. Heater core - which hose?
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-06-2011, 12:53 PM
  3. Heater inlet hose
    By PatrickMcL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2010, 07:59 PM
  4. Motormite Heater Hose !!HElP!!
    By emitchell365 in forum General Tech Discussion
    Last Post: 09-12-2009, 05:41 PM
  5. Which is the hose the goes to heater core?
    By DesertFox in forum General Tech Discussion
    Last Post: 05-16-2009, 06:08 PM
