Thread: '04 GP GT2 Car won't start!! NEED HELP!!!
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 '04 GP GT2 Car won't start!! NEED HELP!!!
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    I have the check engine on, replaced the crank sensor, I can hear the fuel pump turn on and the car still won't run.
    Wife was driving the car then all of sudden the steering wheel got stiff and die out. After that the car won't turn on. So just so sum it all up.
    Battery: Good
    Alternator: Good
    Crank Sensor: Good
    Fuel Pump: Good (I can hear it turn on)
    Anybody??? Any other Ideas???
  2. #2 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    May 2011
    Kansas City
    have you taken a code reader to the car to see what the actual engine code is?
    Reptile Tune (SOLD)
  3. #3 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Sep 2011
    Arkansas
    May not apply on your year, but on my 98 Monte Carlo I had an orange wire come loose behind the ignition switch in the steering wheel. Everything else was fine, but that stopped the car from starting. I don't remember anything more specific because that was quite a few years ago....
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  4. #4 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Use some starting fluid to try to start it and if it does start then you have a fuel issue. I've heard fuel pumps make noise but not make enough pressure to prime the system. Could be a bad pump.
  5. #5 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    check for spark yet?
  6. #6 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Sep 2011
    Arkansas
    Couldn't an extremely clogged fuel filter be the culprit as well?
  7. #7 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    May 2011
    Kansas City
    ive also heard a rediculously clogged air filter can possibly cause it lol
    Reptile Tune (SOLD)
  8. #8 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    Well I don't have a code scanner and obviously can't take the car to the auto store. I've put some air intake cleaner and it turned on for a couple of seconds. I've also tried the old fashion thing, hitting the fuel filter and and tapping on top and bottom of the fuel pump, since I can get to the fuel pump from the inside of the car, and still nothing.
    How do I check for the spark? Do you think it might be the ignition coil?
  9. #9 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    if it started up with some spray, you have spark, test for fuel pressure at the rail.
  10. #10 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    which rail? sorry, I know some stuff, but not that much.
  11. #11 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    standing at the bumper, just past the valve cover you should have a fuel rail with a plastic cap like a tire air stem, open it and you will see what looks like a tire air stem valve. you screw a pressure tester onto it and turn the key to run, the pump primes and the gauge will tell you how much pressure you have.
    you could also try the fuel pump relay bypass trick, if this works it could be the fuel pump resistor.
    this is the under hood fuse box.
  12. #12 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    thats for 97-00 GTP fuel pumps only. I dont think he can do that on his 04+ car.
  13. #13 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Since you know the issue is fuel. Have some one turn the key from off to on while you listen to an injector for it making a few clicks. If you hear that, then your injectors are working and you are just not getting fuel from the pump.
    If the injectors aren't working, I'd check the fuse.
  14. #14 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    ok, so I've checked every single fuse and none of them are burned out, I've also switched around the relays and still nothing.
    Since I don't have a pressure gauge I've put pressure on the rail with my finger and the a key, no fuel squirted out like on my Grand Am. (did the same thing and some fuel squirted out).
    So what could it be now? I'm guessing not fuel pressure, but how do I go about getting pressure. Is that it?
  15. #15 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    time for a new fuel pump.
  16. #16 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    It would appear your pump is not pumping.
  17. #17 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    but can hear the fuel pump turn on and making the hizz noise when turning on the car (not cranking it)
    '04 | GP | GT2 | 162K
    Not an Expert | Just for the love of working on cars
  18. #18 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    if you have no pressure at the fuel rail then chances are the pump is dead.
  19. #19 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    so as long as I just replace the module in the fuel pump it would be ok, right?
    (I did it for my Grand Am just replace the module inside fuel pump and it's working just fine)..
    I rather spend about 50 - 60 bucks than 250 for the WHOLE fuel pump..
  20. #20 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    A few things can be happening here.
    1. Hose popped off fuel pump and it's running, but sending fuel in a circle.
    2. Your pumping air, in case..add fuel. Especially if the sender went bad.
    3. Your pump is bad
  1. No start/help please????
    By 97gmgtp in forum General Tech Discussion
    Last Post: 12-04-2010, 11:11 PM
  2. No start need help
    By Seanstud in forum General Tech Discussion
    Last Post: 11-28-2010, 10:07 PM
  3. Hot start help
    By makenzie71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2010, 09:59 PM
  4. Where should I start?
    By Basher in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2009, 09:44 PM
  5. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
