Thread: No start/help please????
Results 1 to 20 of 20
  1. #1 No start/help please????
    Dec 2010
    connecticut
    Hey everyone, I'm having a problem with my 97 gtp
    The car starts up and dies a few seconds later.
    It feels like it has an transponder key problem but it doesnt have a transponder key.
    If i play with the gas i can keep it running but dies when i let off.
    'Some things i did were....power steering pump line replacement...low pressure line.
    vacuumm line repair...the line from the manifold that runs to the ventilation inside the car...
    other than that i am at a lose.
    The battery did go dead and i did charge it overnight.
    My pickup had a similar problem after the battery was dead for a while...it had to learn tach....
    I drove it in the garage with no issues....went to drive it out and now it wont stay running.
    Anyone have and ideas????
    TIA
  2. #2 Re: No start/help please????
    fuel pressure regulator?
  3. #3 Re: No start/help please????
    Charles City, IA
    Is the security light flashing?
    SMGPFC Two Nipple General
  4. #4 Re: No start/help please????
    Dec 2010
    connecticut
    no security light...i bought a two dollar key and drove the car a few days so i dont think it has a transponder issue...just feels like it.
    Hmm...regulator?..perhaps?
    I forgot to mention i am throwinga code...vacuum purge something.
    It has been that way for a while...i did change the gas cap.
    i hear ther fuel pump running.
    how difficult is the regulator to change?
  5. #5 Re: No start/help please????
    simple as pie, first off, pull the vacuum line off to see if it may be bad. If you pull the line off and fuel comes out, the regulator is bad.
  6. #6 Re: No start/help please????
    Dec 2010
    connecticut
    hey five
    where is it?
    just bought this beater and know little about it
    Last one i had was a new 2000 gt but it had no issues
    can i get that reg at an auto parts place?
  7. #7 Re: No start/help please????
  8. #8 Re: No start/help please????
    Charles City, IA
    Can you keep the car running with the gas pedal?
  9. #9 Re: No start/help please????
    Dec 2010
    connecticut
    yes i can keep it running with the gas pedal but i have to pump it and play with it to keep it running,it eventually dies as i am doing this
  10. #10 Re: No start/help please????
    Charles City, IA
    You have a huge vac leak. Fine it fix it.
  11. #11 Re: No start/help please????
    Akron Ohio
    Im going with this.
  12. #12 Re: No start/help please????
    Dec 2010
    connecticut
    ok guys i pulled the vac line off and no fuel came out...car was not running.
    looks like the regulator is a bear to replace...looks like the metal fuel rails are connected as a one piece unit.
    as far as a vac leak...i did have vac lines that were cracked but the car ran before
    i replaced them.
    there are two vac lines that i messed with...the one from the manifold that feeds a tee under the relay box on the pass fender...one goes to the inside for the heater..th other on i dont know where that goes
  13. #13 Re: No start/help please????
    Charles City, IA
    Take pictures. Also for future reference the fpr is held in buy a snap right and pulls out of the rail, but that is not your issue.
  14. #14 Re: No start/help please????
    Dec 2010
    connecticut
    ok so it doesnt look like the regulator if its no leaking gas right?
    i'm stumped
    i dont think its a vac leak either though
    when it was running i was able to pull vac lines off and it would stay running etc.
    seemss weird it was ok and now its dead
    could it be a tach learn problem?
    like i said before i had a truck that did the sme thing when the battery was dead
    ran like crap and wouldnt stay running with out playing with gas pedal...after 5 or 10 minutes it would calm down and run good again
  15. #15 Re: No start/help please????
    Charles City, IA
    Did you break the vacuum tree that the lines where connected to?
  16. #16 Re: No start/help please????
    Dec 2010
    connecticut
    no i dont think so but like i said the vac line was broken going to it before and the car ran...i just couldnt change from heat to defrost
  17. #17 Re: No start/help please????
    Charles City, IA
    Well start with checking fuel pressure and pull some plugs and see what they look like.
  18. #18 Re: No start/help please????
    Dec 2010
    connecticut
    when i start it without playing with the gas pedal it fires right up and stays running for 4 or 5 seconds. and sounds good
    when i turn the key i hear the fuel pump,then crank and it starts right up then dies
    I suppose it could be fuel pressure...have no clue how to check it
    guess ill look at it again in the morning and see if something came unplugged electrically but i doubt it
    ughh
  19. #19 Re: No start/help please????
    Dec 2010
    connecticut
    Thanks to everybody that tried to help me out!!!!
    I tried starting it this morning and the same thing,start then stall.
    I bent the pin on the relay # 85 and it fired right up!!!!!!!!!!!!!!!!!!!
    You guys are amazing
  20. #20 Re: No start/help please????
    Charles City, IA
    Fuel pump resistor. Never came to my mind.
  1. Not sure where to start...
    By bilak09 in forum Engine
    Last Post: 01-06-2011, 01:46 AM
  2. Car won't start!!!
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 05:49 PM
  3. Car Won't Start
    By mminchau in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2010, 05:36 PM
  4. Where should I start?
    By Basher in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2009, 09:44 PM
  5. The Start
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:43 AM
