Thread: so frustrated with this car
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 99
  1. #1 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by kawasakidrivinghick View Post
    So what you guys think would it cause a misfire code with a bad valve it runs great besides idle so would this do this with a bad valve
    That's a tough call. What I don't understand is why are there no emission system codes. You would think that incomplete combustion in one cylinder would raise a flag.
    Maybe someone else could chime in here?
  2. #2 Re: so frustrated with this car
    new york
    ok what you mean ball-peened a seat?
  3. #3 Re: so frustrated with this car
    new york
    theres no diffrent noice to it, im so frustrated with this thing
  4. #4 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
    Look at it this way. If this is the worst thing that happens to you in your life then you'll have a really good life! And your learning a lot, right?
    I had two 3800 motors go out in one month, by GPGT and my girlfreind's firebird! You talk about suck!
    Anyway, you might have to bite the bullet and remove the head.
  5. #5 Re: so frustrated with this car
    new york
    ebay?
  6. #6 Re: so frustrated with this car
    new york
    yea thats what it is looking like thanks for everyones help, where should i get another head?
  7. #7 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
    Yea, Good 'ole Ebay.
    You could try Morad in Ohio. That's where I got my last short-block. They have a ton of parts. In fact I don't think anyone else in the country has more 3800 parts than them. You could also check a local junk yard but they're usually unwilling to separate the heads from the motor.
    First things first. Get that head off and see what the shiz is.
  8. #8 Re: so frustrated with this car
    Sep 2011
    MI
    Ehhh just throwing this out there. and I'm not sure if you did switch injectors... but... If the injector was shooting too much gas into the cylinder it would wash down the cylinder and lower the compression, and make it miss at idle(too much gas to fire). It wouldn't miss under load because the car would then need the extra fuel.
  9. #9 Re: so frustrated with this car
    new york
    thanks i will try that would it make exhaust smell really really bad
  10. #10 Re: so frustrated with this car
    new york
    how would i tell if it switched with out a scanner, also if i pull the plug the car idle doesnt change?
  11. #11 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
    I see what 99grandprix is saying. A dead injector at idle would have way to much fuel to fire so the idle may not change. Of course low compression will do the exact same thing.
    I guess this is a possiblity. Who knows, maybe you won't have to pull the head. But I don't think extra fuel in the cylinder would drop the compression from 170 down to 60psi.
  12. #12 Re: so frustrated with this car
    new york
    Anyone else have that problem with a injector???
  13. #13 Re: so frustrated with this car
    Sep 2011
    MI
    Switch the #3 injector withn any other injector, unplug the battery to clear the current codes, then drive it. when the light comes back on take it to advanced and have them scan it. Should be free. if the misfire jumps from #3 to where you moved it, you'll know it is the problem.
    And yeah it can make the exhaust smell bad.
    Pulling the plug won't tell you anything because you'd be going from too much fuel to no fuel... either way it wouldn't fire.
  14. #14 Re: so frustrated with this car
    Sep 2011
    MI
    Easy check, pull the fuel pump fuse, pull the #3 plug put a little oil down the cylinder crank it a few times(it will coat the cylinder wall with oil & squirt out the excess) then do a compression test. If compression jumps up to where it should be... then you know.
  15. #15 Re: so frustrated with this car
    new york
    im gonna switch the injector around tomarrow see where that gets me, if it was a valve i would think it would run bad all the way though rpm range but only at idle and it would come and go
  16. #16 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
    I hate reiterate what other people may have already commented on but I think you should check to see if your oil smells like gasoline. With a dead/stuck open injector the excess fuel will make its way down into the crankcase.
    If you don't have any luck with swapping the injector I would suggest checking the pulse signal from the PCM like we discussed on an earlier post. If the problem is something with the PCM then swapping the injector may not tell the whole story. You'll have the same results with a different injector on #3 cylinder.
  17. #17 Re: so frustrated with this car
    new york
    thanks ill check it out
    SE Level Member darionmilton's Avatar
    Jun 2010
    Lansing, Michigan, United States
    Did you check the exhaust manfold gaskey
    Sent from my SCH-I500 using Tapatalk
  19. #19 Re: so frustrated with this car
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by darionmilton View Post
    The problem with kawasaki's car is a misfire on #3 cylinder. I don't think a bad manifold gasket would cause this.
    Go back and re-read the thread. We're looking for some more suggestions before having to remove the head.
  20. #20 Re: so frustrated with this car
    new york
    why
  1. need some help. Very frustrated
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2011, 07:58 AM
  2. Frustrated 4t65E trouble
    By Gman in forum The Rant Forum
    Last Post: 05-24-2009, 12:47 AM
  3. Frustrated in NC
    By Gman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2009, 10:28 PM
  4. FRUSTRATED ..trying to buy
    By Ninjo in forum The Rant Forum
    Last Post: 07-01-2008, 05:56 PM
  5. electrical? I am frustrated!
    By smitch in forum General Tech Discussion
    Last Post: 06-23-2008, 11:02 AM
