Thread: Service engine light
Results 1 to 14 of 14
  1. #1 Service engine light
    Virginia
    My service engine light came on. Went to AutoZone, after they tested it, it came out "catalyst efficiency low-bank 1" Then he tried to sell me a new catalytic converter! I actually read the slip of paper he printed up (and let me keep). I think I'll start small with a tune up, even though the guy at the Zone said I didn't need one. It has 103 K miles and original plugs. then on to trying to find a vacuum leak. I already looked for holes in the exhaust and didn't find any. Wish me luck
    2003 Grand Prix GT Limited Edition.
  2. #2 Re: Service engine light
    Houston
    Quote Originally Posted by buck View Post
    I think thats a good start.
  3. #3 Re: Service engine light
    St. Louis
    Depending on what code it was I would say may be time to add a new upstream O2 sensor (the one on the rear manifold) to your list of tune up items. It would work to your benefit as well since that O2 is in the way of #6 cylinders' plugwire boot anyway.
  4. #4 Re: Service engine light
    Virginia
    It just dawned on me that about a week ago my son ran out of gas in the car. He used a gas can that use to mix two cycle engine oil in. It had about a gallon of 50/50 mix. Then I filled the tank later. My thought is that mabeye the oil gas mix screwed up the 02 sensor. (making the car think there was an oil leak inside the engine). any thoughts?
  5. #5 Re: Service engine light
    Buffalo
    Would this be the ever so popular P0420?
    Causes
    A code P0420 may mean that one or more of the following has happened:
    • Leaded fuel was used where unleaded was called for
    • An oxygen sensor is not reading (functioning) properly
    • The engine coolant temperature sensor is not working properly
    • Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
    • Retarded spark timing
    • The oxygen sensors in front and behind the converter are reporting too similar of readings
    Possible Solutions
    Some suggested steps for troubleshooting a P0420 error code include:
    • Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
    • Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
    • Inspect the downstream heated oxygen sensor (HO2), replace if necessary
  6. #6 Re: Service engine light
    You run your 2 cycles 1 to 1??? Go through plugs much?
  7. #7 Re: Service engine light
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Has your cat been replaced? If an aftermarket converter was used, it may be the problem. I know of several people that have had issues with the P0420 code after a new cat was installed, they simply do not do a good enough job and the code is thrown.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
    SE Level Member GiAnT4LYFE's Avatar
    Apr 2009
    Delaware
    My car just threw this code yesterday.
  9. #9 Re: Service engine light
    Virginia
    O.K. a little exageration. I follow the manufacturers specs. My question is would mixed gas hurt a car
  10. #10 Re: Service engine light
    it's really not good on the cat but one gallon shouldn't really hurt anything i wouldn't think.
  11. #11 Re: Service engine light
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    this just happened to me. what is there to do?
  12. #12 Re: Service engine light
    Houston
    Tune out the code
  13. #13 Re: Service engine light
    Nov 2010
    Illinois
    is that all you can do? i dont want to spend all that money to get it tuned out. and its going to be a while before i drop my pulley and get a tune for that
  14. #14 Re: Service engine light
    Houston
    I have a high flow cat, and the code was removed. You can just let it be until you do the pulley drop and tune.
  1. Service engine light
    By s33dl3ss in forum General Tech Discussion
    Last Post: 07-30-2011, 04:10 PM
  2. Service Engine Soon Light On?
    By ljmonnin12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2011, 12:04 AM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. service engine soon light =[
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:06 AM
