New on the site! Ok i have a 99 gtp. just got it 2 weeks ago. service engine light comes on. its P0741 definition TCC stuck off....explanation TCC commanded on and the ECM detected the TCC slip speed higher than limits......Probable Cause 1 Tcc solenoid failure
2 open or short circuit connection
3 blocked passage in transmission
4 check tranny range switch for proper operation
Ok also just noticed tranny fluid was 1.5 pts low.
Filled it and next night light went off.
Next day after 20 miles of driving light comes on
check fluid and its exactly 1.5 pts low again!
just dont know if the tranny leak has anything to do with the code??
Thanks
