Thread: is this normal...dash light dim out few second at start up?
Results 1 to 11 of 11
  1. #1 is this normal...dash light dim out few second at start up?
    chicago
    on my father's gtp the dash light dim out for few seconds when starting up the car. the battery connector bolt was strip out and loose, but i replace it. could this be an alternator problem or just normal on the 3800 grand prix?
  2. #2 Re: is this normal...dash light dim out few second at start up?
    GTP Level Member SuperSport's Avatar
    Michigan
    I noticed mine does this too. I kept meaning to make a thread on it, but didnt know how to describe it. I would like to know if this is a problem or not too!
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: is this normal...dash light dim out few second at start up?
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    i dont think its a normal problem as my 00 GT never had this problem, but my "new" 99 GTP does have this problem. and its gotten to the point to where half of the dash lights will go completly dim
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  4. #4 Re: is this normal...dash light dim out few second at start up?
    Michigan
    Do they stay dim or for a few seconds?
    When I start my car, when I let go of the key the dash lights dim for about a second, then come back to normal.
  5. #5 Re: is this normal...dash light dim out few second at start up?
    The voltage drops when the car is starting FYI.
    How much depends on the current draw of the starter.
  6. #6 Re: is this normal...dash light dim out few second at start up?
    Michigan
    See its really hard to explain...after the car is started, its like a second before the lights dim, then return to normal. And the rpms dont bog or anything, its like they dim independantly drom the starter or engine load...Id make a quick video, but my car is put away for the winter...
  7. #7 Re: is this normal...dash light dim out few second at start up?
    chicago
    x2 that's exactly how mine is like, i will make a video this week tho.
  8. #8 Re: is this normal...dash light dim out few second at start up?
    It really shouldn't be doing that, do you have a voltmeter in the car?
  9. #9 Re: is this normal...dash light dim out few second at start up?
    GT Level Member BackInBlack's Avatar
    Vermont
    Older alternators may take a second for the voltage regulator to stabilize...?
    The GPs are long gone...
  10. #10 Re: is this normal...dash light dim out few second at start up?
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    I don't think this is normal, my gt don't do that (yours its a gtp but it shouldn't matter) yes, there is a problem with that but I don't know how to fix it lol
  11. #11 Re: is this normal...dash light dim out few second at start up?
    Turns out this is a built in function of the PCM.
  1. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  2. Is this normal
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 11:19 PM
  3. parking brake light on dash
    By Jcal1120 in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2009, 08:16 PM
  4. Normal Oil smell?
    By xerxescct in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 10:45 PM
  5. HID flickering... is this normal?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 06-29-2009, 09:15 AM
