Thread: Need Help with Surging Idle Problem on GTP
Results 21 to 21 of 21
Threaded View
  1. #1 Need Help with Surging Idle Problem on GTP
    Oct 2011
    Norco
    I have been struggling with a surging idle on my 98 GTP. I have replaced the MAF, IAC, PCV valve, Caniser purge valve, TPS and cleaned the throttle body. I have had occasional codes set for idle higher than expected and Evap system flow during non purge. The only code that still comes back is the idle higher than expected but the idle surges, mainly on cold start until it warms up. If I wing the throttle a little (up to 2K rpm or so, when it comes back down it drops way below the normal 750 rpm and oscillates between near stall and 1300 rpm. Once warmed up a little it smooths out but idles at about 850 rpm in gear and the idle higher than expected code comes back eventually.
    Is there actually some kind of idle learn process that I have read about or is that urban myth?
    Any suggestions?
    FIXED!!!! New MAF Sensor Was Bad!! See last Post....
  1. Engine Light on code P0171, IDLE SURGING!
    By balzi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 01:51 PM
  2. Please Help!!! GTP surging idle
    By Damon318 in forum General Tech Discussion
    Last Post: 10-26-2010, 01:05 PM
  3. Surging idle when warm
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 10:21 AM
  4. Surging idle under normal acceleration
    By billy8380 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 10:36 AM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
