Thread: Need Help with Surging Idle Problem on GTP
Results 1 to 20 of 21
Threaded View
  1. #13 Re: Need Help with Surging Idle Problem on GTP
    Nov 2011
    south carolina
    You have to be sure that the pintle in the new IAC isn't out too far before installing it (28mm from the face of the mounting flange to the tip of the pintle cone). Then theres a short procedure to reset the pintle once the IAC in in place turn ign on, then off for 20 seconds, then start the engine). Make sure the passages for the IAC are clean.
    Sounds more like an unmetered air problem to me and the throttle plate needs to be put back at stock.
    With the throttle plate back at stock and the engine idling... if you unplug the IAC, does the engine stall?
  1. Engine Light on code P0171, IDLE SURGING!
    By balzi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2013, 01:51 PM
  2. Please Help!!! GTP surging idle
    By Damon318 in forum General Tech Discussion
    Last Post: 10-26-2010, 01:05 PM
  3. Surging idle when warm
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 10:21 AM
  4. Surging idle under normal acceleration
    By billy8380 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2010, 10:36 AM
  5. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
