You mention the throttle plate was changed. Just the plate or the whole throttle body? Have you taken the Intake tube or airfilter off the throttle body to view the inlet? For the throttle adjustment screw, I just adjusted it a hair after the throttle plate is loose, but I'm sure there's a more correct procedure to make it work correctly with the TPS.
