wheel bearing.
Jack up the front end ender the crossmember in the front and make sure the key is ON so the steering wheel is not locked and start shaking the tires down.
12-6 is wheel bearing
3-9 are ti rods.
if you feel play, you got problems.
I figured it was one or the other, I had both problems on previous vehicles, they share similar symptoms but the tire lean threw me off. I've never had lean with a bad wheel bearing/hub.
One more question though if you dont mind. lol. My "TRAC OFF" light stays on, and from what I hear thats caused by bad hubs also, or a bad connection to the plug on the back of the hub. Is this correct or should I be replacing something else?
