Thread: why does Steering gets stiff
Results 1 to 12 of 12
  1. #1 why does Steering gets stiff
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    As i'm going down the roads, my Trac light, ABS light, and my tire pressure light comes on. And when it comes on, I can feel my steering stiffin up alot. Any idea why this happens? (Lights come on because the sensors are cut on both front wheel bearings). Also, would gas milage be related to these sensors for some odd reason? Becuase right now I went 215 miles and have less then a 1/4 tank. (no codes and mostly highway driving).
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: wy does Steering gets stiff
    because you have magnasteer and it's tied into the abs and trac system.
  3. #3 Re: wy does Steering gets stiff
    fix your car problems, then all will be good.
  4. #4 Re: wy does Steering gets stiff
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    mine did that before.. after that my rack and pinion broke. un related problem.. but i gotta new rack and the problem never happened again
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: wy does Steering gets stiff
    Omaha, NE
    Fix the hubs and your problems should go away.
  6. #6 Re: wy does Steering gets stiff
    Jul 2011
    Michigan
    So could this some how be related to gas milage in some weird way? My gas milage is freaking stupid!!!! lol
  7. #7 Re: wy does Steering gets stiff
    Jul 2011
    Michigan
    I know how to fix the problem, I was just asking why this happens. I knew what was causing it.
  8. #8 Re: wy does Steering gets stiff
    doubtful,
    if you're only driving city, getting 275 a tank is normal.
    maybe its time for a tune up.
  9. #9 Re: wy does Steering gets stiff
    Maybe you just need a tune up? When the weather gets cold your gas mileage will go down quite a bit.
  10. #10 Re: wy does Steering gets stiff
    Omaha, NE
    Quote Originally Posted by BlackGT97 View Post
    If your bearings are causing resistance, it can easily cause your MPGs to go down.
  11. #11 Re: wy does Steering gets stiff
    Jul 2011
    Michigan
    The hubs are good....So I think we can rule that out.
  12. #12 Re: why does Steering gets stiff
    Texas
    Like was posted above more than likely the magnasteer.
    85 Corvette
    01 TA
    03 Z06
  1. Power Steering Stiff After New Pump
    By brandonl2000 in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 01:05 PM
  2. Very stiff brake pedal?
    By Mesaman4 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2010, 05:37 PM
  3. shift selector lever very stiff
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:18 PM
  4. steering
    By noom14921992 in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2009, 05:45 PM
  5. Trans linkage stiff???? Need help!!!
    By drums4life0922 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2008, 11:25 AM
