Thread: cv joint question
Results 1 to 9 of 9
  1. #1 cv joint question
    SE Level Member SilvrGrandPrixGT's Avatar
    Nov 2009
    Indiana
    I have a vibration in the front end of my GP. I have replaced tie rods (which I knew were bad), wheel bearing hubs (also knew these were bad), put new tires on the car, and had it aligned as well. I checked the ball joints and they're a-okay.
    My question is, since I am sill having the vibration problem, is this most likely my CV joints that are shot? It doesn't vibrate much at lower speeds, but it does on the interstate especially when accelerating.
  2. #2 Re: cv joint question
    Banned
    Apr 2011
    wv
    at what speed and under what conditions does this vibration occur?
  3. #3 Re: cv joint question
    Nov 2008
    norman oklahoma
    yes just had to replace my 2000, was vibrating at highway speed also... maybe a sticky on a how to . if u cant find one, either i can tell you or maybe someone can steer u to some info.
  4. #4 Re: cv joint question
    Nov 2009
    Indiana
    55 to 60 usually is the worst ... both for sound and vibration
  5. #5 Re: cv joint question
    Nov 2009
    Indiana
    Is it normal for the CV joint to clank if you jack the car up and rotate the tire back and forth?
  6. #6 Re: cv joint question
    Banned
    Apr 2011
    wv
    noooo its not normal for the wheel to do anything other than spin with a light load due to the transmission.
  7. #7 Re: cv joint question
    Nov 2009
    Indiana
    I knew it! I should quit listening to people who only know how to work on trucks !
  8. #8 Re: cv joint question
    When accelerating?
    Could also be bad factory fluid filed motor mounts and there is enough give at that point in the powerband that your exhaust is coming into contact with something else making that vibration.
    I had bad axles plenty of times...and unless they are perfect...they made noises all the time...I'd have to turn left or turn right to make them shut up at any speed.
  9. #9 Re: cv joint question
    Nov 2009
    Indiana
    Where and how do I check the motor mounts?
  1. Need gtp flex joint.
    By Dirt Diggin GTP in forum Introductions/Noob Questions
    Last Post: 08-09-2010, 11:06 AM
  2. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  3. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  4. Steering / CV Joint?
    By Egleone6 in forum General Tech Discussion
    Last Post: 04-08-2009, 11:08 PM
  5. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
