Pulling the DRL diode behind the drivers side dash disables the DRL's. There is a fuse behind the glove box that you can pull to disable the auto lights. I can't remember which one it is since I pulled mine out years ago. That works fine up to I believe 2000. If you don't want to do that, then you can do this
Headlamp Control
