Thread: Fuel Related Issue??? Or not??
Results 1 to 12 of 12
  1. #1 Fuel Related Issue??? Or not??
    SE Level Member SilvrGrandPrixGT's Avatar
    Nov 2009
    Indiana
    Recently, I have been having issues with my GP stalling while running. It used to occur not very often at all and would almost immediately start back up. Lately, it has been stalling more often and within the last few weeks has become almost undriveable. I replaced the fuel filter, MAF sensor, cam sensor and the fuel pump to try to fix the problem, but it is still stalling out.
    Does anyone have any idea what it might be? Someone said it might be the injectors, but when it is running there is no loss of power at all. It never sputters and/or spits, it just stalls out. It seems as if this would almost rule out a coil pack too, but maybe not. Wouldn't I be losing power if it was a coil pack? I guess it could need spark plugs and wires (maybe a wire is exposed and it's grounding out on the block or something....) It's got me at my wit's end.
    I would appreciate any advice/help with this issue....
  2. #2 Re: Fuel Related Issue??? Or not??
    Nov 2011
    south carolina
    Quote Originally Posted by SilvrGrandPrixGT View Post
    Does it ever stall out while your foot is accelerating or holding steady throttle, or is it when you're off the throttle? Could you keep it from stalling if you were to keep one foot on the gas all the time?
  3. #3 Re: Fuel Related Issue??? Or not??
    GTX Level Member cerick08GP's Avatar
    Without know more about the conditions at the time of the stalling I’d have to go with the CPS (crank position sensor) failing. If your tach gauge freaks out, or maybe an abs light, and generally no associated CEL or code then it probably is the CPS.
    Information like any codes, what speed is the car going, cruising or during acceleration, coolant warm or cold, mileage on your car, any mods you have done are often key to figuring this stuff out.
    Also, have you taken a trip lately? And how long is recently, a week…two? I’m thinking it might be simply water in your gas tank. Did it rain a lot in Indiana lately, did you fill up at a different gas station than usual?
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Fuel Related Issue??? Or not??
    Nov 2009
    Indiana
    Quote Originally Posted by rocknnachos View Post
    No, it stalls even when idling at a stop light or something.
  5. #5 Re: Fuel Related Issue??? Or not??
    Nov 2011
    south carolina
    errr... so it does not stall when your foot is applying throttle... correct? Could you call this an idle problem instead of a running problem?
  6. #6 Re: Fuel Related Issue??? Or not??
    Nov 2009
    Indiana
    Quote Originally Posted by cerick08GP View Post
    It's been happening for a while, ebven in the dry Indiana summer. I fill up at several different gas stations. Usually Shell stations as they seem to have great gasoloine. I don't have any mods on the car, it has about 225k--all original. It will happen even at idle, but usually when driving around or accelerating, no speed inpaticular.
    I took it to Auto Zone last night and didn't get any codes. So you're saying is a CPL not going to give a code? My tach gauge freaks out a lot. Usually when stalling out, but sometmes it will stay running. At times, it will freak out, the car will sputter as if it is going to stall, then the tach will go down to 0 and the car will stay running will the tach remains inactive? Lastly, is the crank position sensor different from the cam position sensor, because I have replaced that already.
  7. #7 Re: Fuel Related Issue??? Or not??
    GTP Level Member AjL227's Avatar
    IL
    I had an issue recently with it spazzing out and stalling on acceleration only. I had a minor leak at the fuel pressure sensor on my ZZP billet rails. Being a dead head / no return fuel system, air got into the injectors. I drove it 10 miles on the highway and filled up with fuel and the issue vanished. How many miles have you been driving with this condition? Has it only appeared after your last fuel fill up?
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  8. #8 Re: Fuel Related Issue??? Or not??
    Nov 2009
    Indiana
    Quote Originally Posted by AjL227 View Post
    It started about 3 months ago. It was only happening once a week or so, now it happens every day, so I started driving my Ranger until I can resolve the issue. I have filled up several times since the issue initially began and used two different fuel injector cleaners as well as replacing everything I mentioned in the initial post. I am stumped....
  9. #9 Re: Fuel Related Issue??? Or not??
    IL
    Do you have any sort of fuel pressure gauge? Hook it up to the factory rail and see where the pressure lies at varying RPM. If only you had a pillar mounted one, like me you could monitor it during loaded driving conditions. However, you can always find a cheap one, wire it through the firewall into the cabin to monitor the issue until you resolve it.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  10. #10 Re: Fuel Related Issue??? Or not??
    Nov 2009
    Indiana
    It stalls when idiling, applying throttle, whenever it takes a notion to do so. It's completely random.
  11. #11 Re: Fuel Related Issue??? Or not??
    Every thing you have describe points right to the crank position sensor failing. They are a PITA to trouble shoot because, yes, they don’t throw a direct code. It is because when it fails the PCM thinks the car is off, hence why it “stalls”. As far as a “cam position sensor”, I don’t know what you’re talking about there.
    Just for future reference it is the little things that ppl don’t mention, in your case the tach indication that can really help us help you. I personally have been spared from any CPS failures, but they do fail often on GPs especially older ones. I do know they are far from easy to change, but ppl do all the time so maybe someone can chime in and point you in the right direction.
    2008GP
    2002GP||sold
  12. #12 Re: Fuel Related Issue??? Or not??
    Nov 2009
    Indiana
    Thanks for the help. The cam position sensor is located behind the water pump pulley on the side of the block. I do know the crank position sensor is located near the harmonic balancer and could be a challenge. I think you have to take the tire off, the fender well out, and so on...at least I have a good idea of what it is. I also talked to a gearhead at work. He seems to think it is a crank position sensor, too. I guess I know what I'll be doing on Christmas vacation......
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Possible fuel pump issue.
    By SleeperGS in forum General Tech Discussion
    Last Post: 11-29-2011, 01:58 PM
  3. fuel sender issue
    By dlz47 in forum General Tech Discussion
    Last Post: 08-11-2011, 12:12 PM
  4. Fuel Pump Issue
    By zildjian102 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:17 PM
  5. Another issue, fuel? please help!
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-22-2010, 12:28 AM
