Hello and thanks for checking out my post. Hopefully I have put it in the right place.
My 2001 Grand Prix (175,000mi) has been treating me great for the past two years so it has been a while since I have been on here. Unfortunately last month three things seemed to pop up intermittently and are now become a consistent problem.
Problem: Power door locks stopped working, I can hear the relay clicking however it seems like the switches are not getting enough power to lock/unlock. Sometimes if pressed several times they will work to a varying degree. At the same time my rear defroster has stopped working. I have located the relay and it still works. When I press the rear defroster button or power door lock switch the radio will shut off. Now radio does not always come on.
Diagnosis so far: I checked the battery and it has 12.5v with car off 14.89 with car on. I have checked all the fuses have continuity, something interesting I noticed was that the three systems I am having problems with are in same row in fuse box. I located several grounds disconnected them, wire brushed and reconnected, to no avail. I wanted to take a look at the back of the fuse box to see if there were any visible signs of a short however its is proving to be a pain so before I go further I wanted to reach out to everyone here for help.
If you have any useful suggestion on what/where I should check I would greatly appreciate your help.
