I have a 2008 GP Base model,put a Pioneer AVIC-X2 in a few years ago, worked great until last night... was driving and noticed it had not turned on with the car... pulled over shut the car down, opened the door to turn the RAP off... started it back up and it came on... ok good, well this morning its off again, tried the same thing... nothing dead
today, checked the 25 amp "Radio" fuse, looked fine, checked it with a continuity meter, checked out...
next thing RAP relay, it was clicking when the car turned on, not always a sign its good though, changed it with another relay same result, just to be sure changed it with the crank relay (since they are the same part) car started fine.... RAP relay is fine....
checked the voltage at the wiring harnes, 0v DC
so its not the head unit, its not the radio fuse, not the RAP relay.... not the head unit.... that else could it possibly be? anything I can check, or wires to follow that should have voltage i can put a meter on? thanks!
