Thread: Just weird. Can someone help me understand this?
Results 1 to 7 of 7
  1. #1 Just weird. Can someone help me understand this?
    SE Level Member Gm Man's Avatar
    Oct 2012
    Elk Grove, California
    I moved my performance shift button to a red led rocker switch next to the heated seat button I wired the + to the 12 volt connector and the - to the ground connector on the switch I didn't connect the acc. connector for the led light the performance shift lights up and works fine on the D.I.C.. I read a forum where a guy said his "performance shift light on the D.I.C. doesn't work but the performance shift light on the I.P. works" now my I.P. light doesn't so I took the I.P. cluster out seen there was no bulb so I went to the auto parts store and bought one and replaced it; now this is where it gets weird I turned the performance shift button on and the led switch lit up and the performance shift light on the I.P. or D.I.C. didn't light up. Again Can someone help me understand this?
    1973 Cadillac Coupe Deville: http://www.cardomain.com/ride/400873...illac-deville/
    1983 Chevrolet Camaro Z28:
    http://www.cardomain.com/ride/400874...vrolet-camaro/
    2000 Pontiac Grand Prix
    GTP: http://www.cardomain.com/ride/400874...-gtp-sedan-4d/
    Quote Originally Posted by Mac Dre of Thizz Nation
    I need cash, Like a car needs gas
  2. #2 Re: Just weird. Can someone help me understand this?
    On the wiring to the stock button, while we realize there is a red and black wire, it's not positive and negative. It's simply a ground flowing through a normal switch.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Yup. One side to ground other to the pcm to enable performance shift. Hope you didnt put 12v into the pcm side.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: Just weird. Can someone help me understand this?
    Oct 2012
    Quote Originally Posted by rperry435 View Post
    No I didn't. I was talking about the rocker switch has 3 connectors at the bottom of it a 12v, Acc., and a ground. I connected the red wire to the 12v connector on the switch and red and black wire to the ground connector on the switch but it worked right tell I got the bulb for the I.P. cluster and put it in. I'm going to take the bulb out and see if it go's back to normal (which I'm sure it will). It's has something to do with the bulb.
  5. #5 Re: Just weird. Can someone help me understand this?
    Oct 2012
    I fixed the problem. Thanks for your guys' ideas.
  6. #6 Re: Just weird. Can someone help me understand this?
    Since you started with two wires..you shouldn't need to ground one. But yeah..
  7. #7 Re: Just weird. Can someone help me understand this?
    cool....mind sharing?
  1. Don't understand the equalizer
    By OKExplorist in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2012, 11:07 AM
  2. Anybody understand Postfix expressions
    Last Post: 04-15-2011, 09:29 AM
  3. Looking at some head-work, don't understand some things
    By copgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2009, 11:23 AM
  4. People who dont understand what a Low gas light is...
    By TorqueAutoMotiv in forum The Rant Forum
    Last Post: 08-20-2009, 10:19 AM
  5. help me to understand
    By vailskier3 in forum General Tech Discussion
    Last Post: 03-22-2009, 09:50 AM
