Thread: 2005 Radio problem..........
Results 1 to 5 of 5
  1. #1 2005 Radio problem..........
    SE Level Member speedy2's Avatar
    NW Florida
    I have an '05 Comp G. My 2 year old son was sitting in his carseat. Not strapped in, as we weren't going anywhere. Just sitting in the car at home. I think I was detailing the interior.
    Anyway, He pulled off the wire going to the rear defogger. Are the radio antennas in this too? Because ever since this happened my radio reception has gone to crap.
    Also, is this repairable?
  2. #2 Re: 2005 Radio problem..........
    canada
    where did he pull it off of? the top drivers side of the window has a little "plug" that plugs into a metal stud in the window. that is ur radio antenna connection. Mine was removed and tucked into the head liner and radio reception was bad. could not get am at all. When I finally went investigating I found the plug and and plug it in and my radio works nicely.
  3. #3 Re: 2005 Radio problem..........
    NW Florida
    Yes that plug. But the plug is still in the cord end. So, the connection is broke. Maybe it can be soldered? I dunno. The window is tinted though.
  4. #4 Re: 2005 Radio problem..........
    New Brunswick
    I would say try soldering or get someone in electronics to do it for you. Might melt a tiny bit of tint but no other choice then to leave it as is or replace the glass.
    Trick is somthing likt that is to have a good soldering iron to get it hot so it melts the solder quickly and gets a good grip.
    Ive dont that with defroster connectors and are pretty much the same thing.
  5. #5 Re: 2005 Radio problem..........
    NW Florida
    Nice to know. I don't have a good hot iron, so I won't even try. If I can get one I will try. But, yeah, don't wanna risk ruining the tint!
  1. Xm radio problem
    By Marqu3ll in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 05:25 PM
  2. 2005 radio install
    By 05grandprixgt in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2010, 12:20 PM
  3. radio display problem
    By rambo33 in forum Audio, Security & Visual Electronics
    Last Post: 12-19-2009, 07:40 PM
  4. Radio Problem
    By nikkigpgt00 in forum Audio, Security & Visual Electronics
    Last Post: 10-03-2009, 10:12 AM
  5. aftermarket head unit radio reception problem
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 06-22-2009, 10:55 PM
