Thread: Quick Question on Stuck Blend Door Actuator
Results 1 to 5 of 5
  1. #1 Quick Question on Stuck Blend Door Actuator
    GT Level Member Panzer4's Avatar
    Dec 2008
    Dubai, UAE/Camarillo, CA/New Delhi, India
    2000 GTP
    90,000 miles
    HVAC requires constant recharging with R134. A leak pressure test doesn't have any obvious signs on a leak on the HVAC lines in the engine bay, and here in Dubai its next to impossible to find R134 with dye.
    The one error code my digital CC gives is a stuck drivers side blend door (code 05 if memory serves).
    Can a stuck blend door actuator cause a loss of R134A over time?
    In a way I'm hoping so because otherwise I'm going to have to remove the support beam and get to the evaporator.
    Thanks for reading.
    "Cry Havoc! And Let Slip the Dogs of War!"
    Black 2000 GTP: 3.4" Pulley, Resonator/U-bend delete, 180 T-stat, Tuned PCM, Thrasher Intake, Larger Radiator, 17" Konig Tantrum Wheels, Red Air Dams. Coming Soon...Projectors, Lighting Mods, Transmission Cooler, Black Rims, Tinted Tails and hopefully Headers
  2. #2 Re: Quick Question on Stuck Blend Door Actuator
    Denver
    Pretty sure not.
  3. #3 Re: Quick Question on Stuck Blend Door Actuator
    Dec 2008
    Quote Originally Posted by SJAndrew View Post
    Pretty sure not.
    Thats what I feared. Thanks though!
    Anyone else?
  4. #4 Re: Quick Question on Stuck Blend Door Actuator
    all the blend door does is move a flap to allow hot or cold air into the car.
    if you are recharging a lot, check all the lines for a dirty greasy mess at the connections, if its leaking a lot you should see some evidence of it.
    dirt will stick to the leak area, its oil left behind at the leak site, so dirty oily mess to look for.
  5. #5 Re: Quick Question on Stuck Blend Door Actuator
    Dec 2008
    Thanks for the great tip man!
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
  3. Blend Door Actuator, my own damn fault
    By chevyy1212 in forum General Tech Discussion
    Last Post: 10-28-2011, 10:54 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
