My blend door motor went bad on the driver side, so unplugged the battery, replaced the motor($60), plug battery in. start car with fans off, listen to blend door motor recalibrate(60 seconds DONT turn fan on) then turn the fan on crank the heat and it worked!
if you havent unplugged your batt to let it recalibrate then thats probably your issue
