Thread: supercharging
Results 1 to 9 of 9
  1. #1 Re: supercharging
    SE Level Member mosinnagant's Avatar
    May 2011
    edgewood
    have a stack of $$$ if you wanna go all the way with it intercooler an everything. but ya if your starting with a bone stock motor upgrade your motor a lil bit before doing this upper swap.
    2007 Grand Prix GT - Green Filter Cone Intake, 180 F Thermostat, EGR Delete, Overkill Custom Tune, Muffler Delete with Thrush Glasspack res swap, Kenwood head unit
  2. #2 Re: supercharging
    SE Level Member LePrix's Avatar
    May 2011
    Ottawa, ON
    Basically start looking for a GTP, much less of a headache for someone like me or you who wouldn't know where to start, and might even be cheaper. Even if you engine swap, then you'll need an HD tranny, so just forget it. Unless you had sex with Angelina Jolie or signed a peace treaty in that GT, its not worth all the time and money to supercharge properly.
  3. #3 Re: supercharging
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by LePrix View Post
    So much wrong information In what was said here its not even funny. You dont need to engine swap, you dont need an HD tranny. A gt will make more power on a m90 then a GTP, and the GT has better gears. Honestly if you have no clue on what your saying why take the time to post?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: supercharging
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    The minimum that you would need to change on a GT to make a GTP would be the Heads and intake manifold, S/C , dampener, idler pulley and PCM programing.
    The N/A eng feeds fuel into the intake manifold and the S/C eng feeds fuel into the heads.
    The only difference in the transmission is the differential and gear ratio to make it a HD. There is also some discussion on weather the HD is stronger or not. GM's HD diff has less gear depth that the nonHD.
  1. question on 3.8 series 3 supercharging
    By gp07 in forum Introductions/Noob Questions
    Last Post: 06-14-2010, 10:59 AM
  2. Supercharging an L36?
    By Todd0990 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2009, 09:30 PM
  3. supercharging my grand prix
    By UTIguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2009, 08:17 AM
  4. SuperCharging Questions
    By straight_upprix05 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 04:14 PM
  5. Supercharging my 00 GT, help please
    By robahr24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2008, 02:35 AM
