so last night it was raining, the wind shield started to fog up, so i hit the defroster, turned up the heat, and all i get is a/c cold air. i did grab the heater core hoses and they are both hot.
my car does have the digital dual climate control unit too. nothing different happens when i switch to manual dual control, its still got no heat.
when i got this car it had the hot air on one side cold on the other problem, but unhooking the battery would reset the actuators i guess and it would work just fine.
so i've used only the a/c since like April and it worked perfectly the whole time, ice cold both sides.
so i unhooked the battery last night, and this morning the heat still dont work, and now when i start the car it cranks at least 5 times before it will fire up, it used to fire up on 1/2 a crank. happened here? is the pcm relearning or something? this has never happened before to this car, and ive had the battery unhooked a bunch of times before. other than the excessive crank to start it its running fine, no cel lights or anything.
