ok little update, the car is back to starting with in a crank, runs great. the heat is now ice cold on the driver side, hot as hell pass side, no mater what the temp control says. the fans not coming on when i hit the button to raise the speed, so if i set it at 5 its stays at 1, if i let it sit for a bit and hit it to 4 the fan will step up to 4, but still not be responsive.
its done this before, a long time ago. so unless you guys have any ideas what could be messing with it. im going to let it go for a day see if comes around on its own like last time, if not ill try unhooking the battery again.
im thinking its time for a new climate control, its been repaired for the lights and still have a few out so it may be worth a shot. unless any of you guys with regals have seen this before.
