Thread: regal with no heat
Results 1 to 16 of 16
  1. #1 Re: regal with no heat
    my climate control acts stupid for a few min after reconnecting the battery
    mine is acting stupid all day lol
    even tried pulling the fuse for it, to give it a hard reboot, no change.
    every time i pull the battery this happens too. frigging blow job.
  2. #2 Re: regal with no heat
    now its cold on both sides no matter where the temp is.
    the fan, now get this, i push the button up to 5, it dont spin any faster till the temp display goes back to outside temp, then i hit the fan button, it will go to what ever setting its set on.
  3. #3 Re: regal with no heat
  4. #4 Re: regal with no heat
    and now the outside temp says 64 deg, its clearly in the 80's today lol
    the fan is still not working right, but i got a/c still on both sides, no heat needed right now lol
  5. #5 Re: regal with no heat
    ok little update i guess, i got to removing the driver side actuator, and was able to turn the shaft and make the d/s go from hot to cold, but the pass side is on its own actuator. so i get that one off, and the shaft is really hard to turn i had to use pliers to turn it.
    i worked the temp buttons and the actuator was turning, but as hard as the shaft was to turn i bet it just couldent get the job done.
    any one ever see this before?
    oh and i found this under my glove box, have no idea what it is....
  6. #6 Re: regal with no heat
    i lubed up the shaft and its turning better, but the actuators not turning the shaft all the way, so i figure i should just change both of them.
    i found the new part # for the pass side actuator, but cant find the driver side one listed anywhere .
    the # i have for the driver side is 18163982, i cant find this one, need help, what # should i use?
    the pass side is 16163982 replaced by # 52402588 or 89018365, the new # for doorman is 604-106 of course this is the $100 one.
  1. No heat in car
    By jibberlo in forum General Tech Discussion
    Last Post: 02-27-2010, 01:08 PM
  2. Heat
    By mongoclark in forum General Tech Discussion
    Last Post: 02-05-2010, 09:13 PM
  3. Low heat
    By citydriver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2010, 08:20 PM
  4. Heat???
    By newmarket23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 12:44 AM
  5. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
