Thread: Blinking Check Engine Light
Results 1 to 20 of 30
  1. #1 Blinking Check Engine Light
    Jul 2011
    westvirginia
    2001 Grand prix gt, runs perfect. floor it and it pulls just fine...till it gets around 80+ then SOMETIMES the check engine light comes on blinking which i know that means the engine is screaming "Oh F*ck Sh*t" but it makes no noises at all...it does stop pulling but if i let off and it up shifts it will pull agin a bit. if i let off and cruise, or even let it up shift and keep it at 80 the light will go off after maybe a minute, sometimes even 10s after i let off the gas.. Any ideas?. I have put it in first and ran slow all the way up through rpm range with no problems if that helps.
  2. #2 Re: Blinking Check Engine Light
    The Boss Iceman6669's Avatar
    Jun 2011
    I have read that a flashing light means Multi-Misfires. It could maybe be your ICM?
  3. #3 Re: Blinking Check Engine Light
    flashing means misfire
    pull the plugs and look for damage to them, or they are just old and need to be changed.
    also the wires may be old aswell and need to be changed.
  4. #4 Re: Blinking Check Engine Light
    Omaha, NE
    Multiple Misfires is correct.
    Along with plugs and wires, check your coil packs.
    Stop driving with a flashing CEL. You're gonna blow your motor.
  5. #5 Re: Blinking Check Engine Light
    Houston
    Check your plugs for this
  6. #6 Re: Blinking Check Engine Light
    St. Louis
    ^^ The infamous "electrode-delete" mod
  7. #7 Re: Blinking Check Engine Light
    Jul 2011
    westvirginia
    yes, but the light is NEVER on during normal driving, so should i be really worried about it? I just don't get what speed has to do with the light, figured higher rpms would trigger it in all gears? idk, maybe the gt is confused its going over 60mph lol >.>
  8. #8 Re: Blinking Check Engine Light
    SE Level Member jarkayman's Avatar
    Aug 2011
    CNY
    It's already been said about the blinking light. It's telling you something bad is happening.
    Throw a decent scan tool on the car and evaluate the info.
    Off the top of my head, at that speed, the torque converter locking up comes to mind.:idk: Just trying to consider what's going on at that speed.
    What RPM at 80 are you at? Are you accelerating or does it only happen when cruising.
  9. #9 Re: Blinking Check Engine Light
    Jul 2011
    westvirginia
    it happens when your accelerating, it never happens when cruising at 60, even 70..and 80+ means it has happened at 80mph before, but usually its around 90-100 it starts. I gotta work so ill try and pull the plugs when i get back. How much do plugs,wires, and coilpacks cost on these cars? (never had a 3800 befrore) Any sparkplug/heatrange you'd recommend for better performance?
  10. #10 Re: Blinking Check Engine Light
    Aug 2011
    CNY
    Quote Originally Posted by mattstansbury View Post
    I'd suggest slowing down.
    Also wouldn't just start throwing coil packs or anything expensive on the car.
    You should give it a solid tune up. That's a given. I'm not convinced that's your problem though if it's only doing it at high speed and no other ranges. It would be a good idea to get a good scan tool (if problems still exist after tune up) and monitoring what's doing what at the point of failure and at normal operation.
  11. #11 Re: Blinking Check Engine Light
    SWPA
    You are going to end up killing yourself, or worse someone else driving the way you do. Slow down.
    Figure out what is wrong with the car before you blow it up.
  12. #12 Re: Blinking Check Engine Light
    Houston
    Mine did the same thing, only upon acceleration above 70 mph. I pulled the plugs and that is what I found.
  13. #13 Re: Blinking Check Engine Light
    Jul 2011
    westvirginia
    So what is the recommended sparkplug heat ranges for N/A 3.8?
  14. #14 Re: Blinking Check Engine Light
    just get ac delco plugs if your staying stock.
  15. #15 Re: Blinking Check Engine Light
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    same thing for me! only mine also happened when i accelerated past 90 mph. light blinked and was off by the time i got home. had some mileage on it and i know i needed a tune up. pulled my plugs, and cylinder 2 was f**ked but not as bad as that one up there ^^^ lol plugs are cheap and dont hurt to get knew ones. throw those in and if you want get wires too. then see what happens.
  16. #16 Re: Blinking Check Engine Light
    Jul 2011
    westvirginia
    should i get plugs and wires anyway? the car has 106,XXX miles. Also, should coil packs be changed?. I've yet to pull the plugs..ah procrastination, but looked at them and they seem like a ***** to get out on the radiator side...didn't look at the back, i was more interested in changing those POS headlight bulbs.
  17. #17 Re: Blinking Check Engine Light
    Jun 2011
    Detroit, MI
    I would worry about the engine rather than looks for right now.
    iLoveSpade
  18. #18 Re: Blinking Check Engine Light
    MO
    Yeah do plugs and wires and go from there. It could really be missing that high up but you're not feeling it because of road conditions or whatever.
    <brandonl2000> LMAO D!!
  19. #19 Re: Blinking Check Engine Light
    Flashing check engine light per the FSM's mean that there is a potentially catalyst damaging condition occuring.
    Typically it's a misfire of sorts.
    What plugs, wires and coils are on the car? Seems like you are getting issues at high rpm. MSD coils are known for this (red and say msd on them)
  20. #20 Re: Blinking Check Engine Light
    Destroys cars izup69's Avatar
    Iowa
    Coil packs are not known for going out. Just like everyone said pull the plugs and don't hotrod it till you do otherwise you might face the dreaded rebuild mod.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  1. blinking Check Engine Light
    By gpgtsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2010, 06:10 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Blinking service engine soon light.
    By lutman123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 11:27 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
