Thread: A-Pillar
Results 21 to 40 of 69
  1. #21 Re: A-Pillar
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Volts, and A/F gauge and im sure my boost gauge but i just ordered that yesterday so im not sure
  2. #22 Re: A-Pillar
    Houston
    Weird, mine didnt have that. The headlight wire is the yellow wire that connects to the switch you use to turn your headlights on. You can get to it by popping that panel off on the driver side of the dashboard
  3. #23 Re: A-Pillar
    Jun 2011
    It says in my instructions thats a dimming feature but i dont need that if i dont want too, if i were going to use that, i should tap into my yellow headlight wire then?
  4. #24 Re: A-Pillar
    Houston
    Hmmm....they must have added that since I bought mine. You connect that, not to the yellow wire, but a brown wire. There are two of them. You want to tag the brown wire that is the second from the end. The brown wire on the end of the harness is the parking light wire. The brown one just inside of that one is the dimmer. Its in the same place...just remove that cover that you see on the driver side dash, once you open the door.
  5. #25 Re: A-Pillar
    Jun 2011
    Installing my A-pillar wont be to hard. lets say i do keep my A/F gauge, where would that connect too?
  6. #26 Re: A-Pillar
    Houston
    To the purple wire on the harness that goes to the o2 sensor in your downpipe. But it really is just a wasted gauge. It will do nothing but bounce up and down and give you no data what-so-ever. Go ahead and see for yourself.
  7. #27 Re: A-Pillar
    Jun 2011
    Wheres the harness that contains the purple wire? actually on the Down Pipe or in the engine somewhere? I saw on Youtube that it just goes crazy
  8. #28 Re: A-Pillar
    Houston
    Here's an example..
    Air/fuel ratio gauge idle/rev - YouTube
    The o2 sensor is in the downpipe. The harness that connects to the o2 sensor is where you'll find it. There are three wires. One of them is purple.
  9. #29 Re: A-Pillar
    Jun 2011
    So im going to have to jack my car up or something to get underneath the car. how do i tap into a wire? im kinda freaked out to accidently cut the wire. how can i get to the wires safely?
  10. #30 Re: A-Pillar
    Houston
  11. #31 Re: A-Pillar
    Jun 2011
    I'm sure Autozone or someplace like that will carry those. I guess i truely dont need to spend $200 to get it installed, i can just do it myself im sure. in what area in the engine bay should i look for the purple wire for o2 sensor?
  12. #32 Re: A-Pillar
    Houston
    They will carry those.. I would not pay somebody to install something you are gonna want to remove. If you want to do it, here is where you want to connect. (This is on the driver side, towards the firewall )
  13. #33 Re: A-Pillar
    Jun 2011
    Even if I'm not going to use the AF Gauge, I just dontvwanna spend so much money to get it installed when I can myself. You really helped man, basically walked me through this whole installation. Thanks Alot!
  14. #34 Re: A-Pillar
    Houston
    Thats what this site is for. It has helped me tons.
  15. #35 Re: A-Pillar
    Jun 2011
    Yeah it's made me learn Alot. I'll get back to you and let you know how the install went
  16. #36 Re: A-Pillar
    Jun 2011
    Oh and also, should I connect the constatnt 12v red wire and black negative wire of the volts gauge right up to the battery directly?
  17. #37 Re: A-Pillar
    Houston
    No, you can connect to the same place you do for your other gauges.
  18. #38 Re: A-Pillar
    Jun 2011
    I looked under my steering column and theres a big red solid color wire, right next to a big solid yellow wire. Mainly all the rest of the wires were a whole bunch of little ones. is that large red wire my constant 12v?
  19. #39 Re: A-Pillar
    Houston
    If you're looking at the correct wires...then yes. The red will be constant 12v, the yellow you wont need, thats your starter wire. If you could take a pic, I'll point out the correct wires. Also what year is your car?
    If you dont plan to solder to your ignition wires, you may want to buy an "add a circuit" and just go to your fuse box in the glove box. (you can find them at autozone, but the link is so you can see what it looks like.
    http://www.amazon.com/gp/product/B00...nce&n=15684181
    I just think its faster to solder to the ignition harness, and you dont have the run the lines as far. But if you dont plan on soldering, then you will want to go that route.
  20. #40 Re: A-Pillar
    Jun 2011
    Alright, i got alot of pictures for you. My car is a1997 Grand Prix GTP completely stock engine and trans wise. First pic is of car, second and third pics are the wires under steering column all from different angles. Fourth pic is this wire harness with a purple wire (is that for AF Ratio?) and fifth pic is of general area of where purple wire is. Sixth, Seventh, and Eighth are pics of what i believe to be the Vac line of what i need to cut to put in the "T" for my boost gauge
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
  1. A pillar
    By TurosGTP in forum Visual/Body Modifications
    Last Post: 03-23-2016, 10:58 AM
  2. 3 pod A-pillar for 04+ gtp???
    Last Post: 03-21-2016, 08:39 PM
  3. Pillar Pod
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2010, 12:52 PM
  4. a pillar
    Last Post: 03-24-2009, 11:59 PM
