Thread: A-Pillar
Results 41 to 60 of 69
  1. #1 Re: A-Pillar
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Alright, i got alot of pictures for you. My car is a1997 Grand Prix GTP completely stock engine and trans wise. First pic is of car, second and third pics are the wires under steering column all from different angles. Fourth pic is this wire harness with a purple wire (is that for AF Ratio?) and fifth pic is of general area of where purple wire is. Sixth, Seventh, and Eighth are pics of what i believe to be the Vac line of what i need to cut to put in the "T" for my boost gauge
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
    [IMG]
    [/IMG]
  2. #2 Re: A-Pillar
    Jun 2011
  3. #3 Re: A-Pillar
    Houston
    These are the ignition lines. The red will be 12v constant, if you cut that tape off of there, there will be a pink line that is switched 12v
    This is the general direction of the o2 harness, should be next to the trans fluid dipstick
    You can see the trans dipstick tube to the right of the harness.
    Cant really tell where that vac line is. The boost line needs to be connected after the T under the supercharger snout by the alternator. A T should be supplied with the gauge, just cut the line by the alternator, insert the new T and connect the lines back together along with the boost line.
  4. #4 Re: A-Pillar
    Jun 2011
    For boost I took a pic of a small black line that starts under the snout (as seen in the picture) and runs under the alternator and to the other side of the engine. I hat figures I cut that line and insert the boost hose cause that's the only small line I see that's under the snout and by the alternator.
  5. #5 Re: A-Pillar
    Houston
    Yes, thats the one.
  6. #6 Re: A-Pillar
    Jun 2011
    Do t-tap come in different sizes? I know I'll need a couple 18 gauge t-tap but what size for the constant 12v large red wire?
  7. #7 Re: A-Pillar
    Jun 2011
    So I should add a fuse for my constant 12v and t-tap into the switched 12v? What fuse would you suggest to add in for constant?
  8. #8 Re: A-Pillar
    Houston
    Im really not sure without testing the fuses. (I never go to the fuse box so I dont know which ones are constant). The radio fuse should be switched, but I've run across some that arent. If you have a multimeter or test light you can go and test them to find the constant and switched. If not, I will test them tomorrow and let you know.
  9. #9 Re: A-Pillar
    Jun 2011
    I need 3 constant fuses, so thanks! Right now the car is in the shop to get fixed but when I get it back I'll take a picture for the dimmer wire that I need to t tap into. I just wanna make sure I know everything before I just start messin with wires. Just double checking since your helping me out Alot
  10. #10 Re: A-Pillar
    Houston
    No, you only need 1 constant fuse and 1 switched fuse. You just pop in the "add a circuit" and tie in all your gauges constant lines to the constant fuse. And tie in all the gauges switched lines to the switched fuse.
    Basically you run one line from the switched fuse and one line from the constant fuse. Run those lines to your "a" pillar. Then tie all your lines together there.
  11. #11 Re: A-Pillar
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Wow this thread is really helpfull. Pretty much doesnt matter what wire you tap into as long as its red or white its a constant power source. Kinda happy these things arent that hard to do.... Hmmmm It would be cool if this thread (when your done helping this young fellow of course) could be shortend up a bit and made a STICKY for sure.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  12. #12 Re: A-Pillar
    Jun 2011
    Didn't think of that. That's a good idea, saves me time and money. Thanks for that tip
  13. #13 Re: A-Pillar
    Houston
    Ok here is where I found the constant and switched 12v on my fuse panel. Yours may be different since yours is a 97 (I dont know if they changed anything) On the cover/pocket that you remove to get access to the panel, is a fuse map. See if you have one labeled "radio amp", I know you have one labeled "radio"
  14. #14 Re: A-Pillar
    Jun 2011
    I'll check to see if I have the radio amp, I'm sure I'll do. When i get my car back tomorrow I'll let you know. Thanks!
  15. #15 Re: A-Pillar
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    dudeeee i totally needed this!!! thanks !!!
    Smgpfc
  16. #16 Re: A-Pillar
    Jun 2011
    Yeah this guy has really helped me out Alot. He's saved me $200
  17. #17 Re: A-Pillar
    Jun 2011
    Just wondering, My car has 131,000 miles and i don't think the supercharger oil has ever been replaced. Should I do that?
  18. #18 Re: A-Pillar
    Houston
    Its really up to you. Ive had a couple dealerships tell me that it doesnt really ever need to be changed, and that it should be good up to 250k miles. But if you want to change it, it's definitely not gonna hurt anything. Unless you dont fill it up enough.
  19. #19 Re: A-Pillar
    Jun 2011
    I Just baught 2 bottles of GM supercharger oil 4oz. The stock supercharger needs 6oz of it, so ill have to put in one and half bottles of oil correct?
  20. #20 Re: A-Pillar
    Houston
    It should be about 1.5 bottles. Just fill it up to the bottom of the threads on the hex plug. To remove the old oil, just get the top off a spray bottle and a cup and shoot the oil into the cup. Just be prepare for some serious stank.
  1. A pillar
    By TurosGTP in forum Visual/Body Modifications
    Last Post: 03-23-2016, 10:58 AM
  2. 3 pod A-pillar for 04+ gtp???
    Last Post: 03-21-2016, 08:39 PM
  3. Pillar Pod
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2010, 12:52 PM
  4. a pillar
    Last Post: 03-24-2009, 11:59 PM
