Thread: Water in car
Results 1 to 7 of 7
  1. #1 Re: Water in car
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    ya passenger floorboard and it just rained... So you guys think its coming from the vent? I'll look into it more tomorrow. I just soaked the water up for now, moved some cars, and put it in the garage. I hope its that flap scottydoggs is talkin about. that will be the first thing i check.
    Thanks guys
  2. #2 Re: Water in car
    pull the carpet up at the side and top of the floor where it goes up, there is foam under the rug that is up to 4 inches thick, it holds water for ever, and stinks. i lifted mine and propped it up with some tools and aimed a fan at it, and coated the carpet with baking soda, use a shop vac to vac it up, the soda can kill a regular house vac, or the car washes vac.
    the water actually leaks from under the rug, and soaks threw to the top.
    and there is a rubber plug/drain in the floor under the rug too, you can pull that and push water down the hole as well.
  1. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  2. '04 GP GTP Water Leak (Different)
    By Jadentsu in forum General Tech Discussion
    Last Post: 06-23-2010, 12:22 AM
  3. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  4. Water, water, everywhere!
    By TheDesertFox in forum General Tech Discussion
    Last Post: 06-20-2009, 02:23 PM
  5. Water in Oil
    By JosephJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2009, 06:03 AM
