Thread: Water Pump
Results 1 to 3 of 3
  1. #1 Water Pump
    Michigan
    Noticed leak passenger side. Jacked car up went underneath right where the oil filter was seemed where the leak was coming from. As you are on you back looking up at the engine you have the oil filter to the right of you and there seems to be a housing on some sort that seems to be leaking radiator fluid. Another location is it is right underneath the alternator. Could it be the weep hole of the pump dripping down causing that. I have no idea what the heck it is. I have a 1997 Pont.GP Supercharged. Thanks
  2. #2 Re: Water Pump
    Jan 2009
    Tallahassee, FL
    I just replaced the WP on my car, weephole was leaking. If you go through this I'll save you some pain and tell ya you have to pull/loosen the PS and the idler puller to the right of it.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Water Pump
    Charles City, IA
    sounds like your coolant elbows in the alternator bracket are leaking.
    SMGPFC Two Nipple General
  1. Water pump issue
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-18-2010, 12:47 AM
  2. Stupid water pump
    By rocafella2032 in forum The Rant Forum
    Last Post: 10-13-2009, 02:02 PM
  3. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
  4. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  5. water-pump's possibly going out?
    By fst in forum General Tech Discussion
    Last Post: 09-02-2008, 08:49 PM
