Thread: Water in car
Results 1 to 7 of 7
  1. #1 Water in car
    SE Level Member hockey101's Avatar
    Detroit, Michigan
    I got in my car to find a good sized puddle on the floor of my car. I don't really know where it came from but after talking with a few friends we ruled out the heater core because the puddle doesn't smeel, look, or taste like it has antifreeze in it. The puddle smells like old musty water, like it was sitting in a steel pipe for a while. One of my buddies dads thought the A/C condenser line may have burst. I'm just wondering if anyone else has had this problem or if they have other ideas of the puddle could have come from. TIA
  2. #2 Re: Water in car
    pass floor board right?
    and it just rained?
  3. #3 Re: Water in car
    http://www.grandprixforums.net/water...-fix-6961.html or oyu could do what i did.
    i took a thick plastic bag cut it and tucked it under the lip where the original flap is tucked in, folded it to the other side and caulked both sides at the top with a thin bead of caulk just to hold it in place, mines been like this for a year now and still dont leak.
    ideally some kind of peel and stick rubber would work too, or some old rubber tube and rubber cement would work as well, just gluing a patch on the old flap, if you know what i mean.
  4. #4 Re: Water in car
    Detroit, Michigan
    ya passenger floorboard and it just rained... So you guys think its coming from the vent? I'll look into it more tomorrow. I just soaked the water up for now, moved some cars, and put it in the garage. I hope its that flap scottydoggs is talkin about. that will be the first thing i check.
    Thanks guys
  5. #5 Re: Water in car
    pull the carpet up at the side and top of the floor where it goes up, there is foam under the rug that is up to 4 inches thick, it holds water for ever, and stinks. i lifted mine and propped it up with some tools and aimed a fan at it, and coated the carpet with baking soda, use a shop vac to vac it up, the soda can kill a regular house vac, or the car washes vac.
    the water actually leaks from under the rug, and soaks threw to the top.
    and there is a rubber plug/drain in the floor under the rug too, you can pull that and push water down the hole as well.
  6. #6 Re: Water in car
    Waukesha, WI
    i had a rock stuck in the drain plug. cut a x into the end of it and added that drip pan thing for the cowl and all is well
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  7. #7 Re: Water in car
    Aug 2011
    Indiana
    I had a cracked cylinder type thing for the wiper fluid, and i kept getting fluid in the floor of the pass side floor.
  1. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  2. '04 GP GTP Water Leak (Different)
    By Jadentsu in forum General Tech Discussion
    Last Post: 06-23-2010, 12:22 AM
  3. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  4. Water, water, everywhere!
    By TheDesertFox in forum General Tech Discussion
    Last Post: 06-20-2009, 02:23 PM
  5. Water in Oil
    By JosephJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2009, 06:03 AM
