Thread: weird stutter after 1.8 rr install
Results 1 to 20 of 22
  1. #1 weird stutter after 1.8 rr install
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    So installed 1.8 roller rockers 2 weekends ago and was pretty easy on the engine since and the odd time I get on it and make boost it stutters for a second and was wondering if anybody has had this issue?
  2. #2 Re: weird stutter after 1.8 rr install
    Re-check the rockers.
    What did you TQ them to?
    Also...TTY bolts or CC Re-Useable ones?
  3. #3 Re: weird stutter after 1.8 rr install
    Charles City, IA
    Might have messed up a plug wire pulling them off
    SMGPFC Two Nipple General
  4. #4 Re: weird stutter after 1.8 rr install
    Aug 2008
    I reused the stock bolts and tq to 24lbft, I ordered new cc reusable bolts should get them tomorrow, and plug wires is a good thought!! I will have to get the stockers out and put them on to see if its them, rather wires than the tear down!
  5. #5 Re: weird stutter after 1.8 rr install
    Your not supposed to use TTY bolts....minus the crank and cam bolt.
    lulz.
  6. #6 Re: weird stutter after 1.8 rr install
    Stock springs?
  7. #7 Re: weird stutter after 1.8 rr install
    PA
    In all reality, there probably isn't an issue with reusing the stock bolts or springs that is going to cause him an issue like this.
    I would rather think you have a vacuum leak or problem with the plugs and wires.
    2001 GSE
  8. #8 Re: weird stutter after 1.8 rr install
    I had a rocker get loose...like the bolt was jsut finger tight...and it had play in it.
    When I'd get on it...it'd studder.
  9. #9 Re: weird stutter after 1.8 rr install
    PA
    I know that if you don't clean the oil out of the bolt holes, it can get tight and to the torque limit. Then as the oil seeps up through the threads, it will get loose.
    I always make sure to spray the holes out with an air hole. Then pour in a little alcohol, clean with a Q-tip, and spray out again. This makes sure the bolt holes are clean and I get a good torque reading and the bolts don't come loose over time.
    2001 GSE
  10. #10 Re: weird stutter after 1.8 rr install
    Take a die grinder...cut a line in the side of the threads...then run it down...and then back it out. Does what a Q-Tip does and so much more
  11. #11 Re: weird stutter after 1.8 rr install
    PA
    There shouldn't be any dirt in there. I just use the q-tip to move the alcohol around a bit that I dumped in so it evaporates a little faster. And it does get some more oil residue out. But running a makeshift tap down through threads that don't need tapped isn't going to do anything. Unless you dumped dirt down there or something.
    What is your reasoning behind it?
    2001 GSE
  12. #12 Re: weird stutter after 1.8 rr install
    Because there is thread sealant on those bolts from the factory. You'd be amazed at how much gunk comes out of the threads even after using a Q-Tip.
    I wish I had pictures of my buddy's rocker install...nastysauce.
  13. #13 Re: weird stutter after 1.8 rr install
    I never clean the holes. I like them dirteeeee. Honestly, I never clean them. I do rotate the motor a bit and retorque though. There shouldn't be any oil in the bolt holes. ...Right?
  14. #14 Re: weird stutter after 1.8 rr install
    PA
    Eh, I could see that. But why not use a tap?
    2001 GSE
  15. #15 Re: weird stutter after 1.8 rr install
    Because cutting a bolt is free
  16. #16 Re: weird stutter after 1.8 rr install
    PA
    2001 GSE
  17. #17 Re: weird stutter after 1.8 rr install
    Don't judge.
    Your jealous.
  18. #18 Re: weird stutter after 1.8 rr install
    Aug 2008
    so i just changed my plug wires and that didnt fix it, BUT the aeroforce doesnt say its a misfire?? it could be a plug but it should show a miss right?? i also received my new bolts and gaskets today so hopefully this weekend i get time to rip it apart again!! cutting a bolt is a good idea but id need a qtip to get all that shiz out lol and yes stock springs i thought about valve float but thats at higher rpms, and it does it before 4k sometimes so??
  19. #19 Re: weird stutter after 1.8 rr install
    Topeka, KS
    I'd recheck the bolts. Get em replaced and tq'd down and see what happens.
    And nick... We haven't done my car yet so lord knows how nasty it's gonna be. You remember what we found under my spoiler lol.
  20. #20 Re: weird stutter after 1.8 rr install
    Aug 2008
    So last night on my way to work I got 4 codes!! P0069, P0300, P0420, P0228. So today in this heat I decided to pull the plugs and check them and guess what I found, cylinders 1-3-5 plugs looked like the iridium tips had melted!! So I replaced the plugs with my spare BRISK plugs and she runs strong now!! Now my problem is passing emissions I think the high flow cat (magnaflow) is scrap for passing, so now I have to replace the 3" with the stock dp then hope it passes!!
  1. 05 GTP Comp G Engine Stutter
    By mrnodaysoff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2011, 08:22 AM
  2. Stutter/jerking going up hills or small inclines
    By robert3112 in forum General Tech Discussion
    Last Post: 12-29-2010, 02:38 PM
  3. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  4. 2000 SE 3.1L engine stutter
    By ejstark in forum General Tech Discussion
    Last Post: 06-30-2009, 01:03 PM
  5. Engine stutter apon downshift?
    By Bogers99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2008, 02:58 PM
