Take a die grinder...cut a line in the side of the threads...then run it down...and then back it out. Does what a Q-Tip does and so much more![]()
There shouldn't be any dirt in there. I just use the q-tip to move the alcohol around a bit that I dumped in so it evaporates a little faster. And it does get some more oil residue out. But running a makeshift tap down through threads that don't need tapped isn't going to do anything. Unless you dumped dirt down there or something.
What is your reasoning behind it?
