On a 1997 grand prix 3800 se, what is the fuse that controls the auto lights because mine will not turn off when the car is running even when it is very bright and sunny out.
This. Your lights are fine.
Im a little confused because you say low power mode but it is the same brightness all the time even if i flip the switch into the full on position they literally will not turn off or dim.
Pull the DRL fuse and call it done (if this trick works on the 97's- dunno). Then you not only save some wear on your headlight capsules by not having the extra heat from the bulbs on all the time, you get full MANUAL control of what lights are on and when. Nothing worse than sitting in a Sonic or the like and having the headlights blazing away just because you want to run the A/C while you eat.
Yep thanks it worked haha and did it right in time because i was racing my buddys eclipse and then the cops were trying to pull us over because we passed the cop doing at least 95 so i pulled in a sub-division and was able to turn off my lights.....haha so thanks alot helped me alot!!!!!!
i know but if you do 30+ over the speed limit here in Illinois it is considered attempted manslaughter and you will be put in jail for 6 months and lose your license for good... So i kinda figured it was worth a try....
Because I want to save wear on my headlights, and have full control of when I turn them on not when the car thinks I should. I typically run w/ my sidelamps on, but not headlights during the day. I have yet to have someone say that they couldn't see me. If I really need to be seen I'll flip on the HID fogs. Can't miss them!
