Thread: Bolt size and torque spec thread.
Results 1 to 20 of 27
  1. #1 Re: Bolt size thread
    Aug 2011
    Arizona
    My son just bought a 1997 Grand Prix GTP. What is the size of the Valve cover bolts? There is one missing on the front cover, and the threads are stripped. I want to use a Helicoil to fix it, but I need to know what size I need. It's a great car otherwise. Thank you for the help
  2. #2 Re: Bolt size thread
    SE Level Member Phyrstorm's Avatar
    Jun 2010
    Sioux Falls, sD
    Quote Originally Posted by flynnaz View Post
    The bolt itself is 1" long from tip to the bottom of the flange and is a 3/8" head. It has a non removable (as far as I can tell) metal washer and stem that hold the rubber grommet on it. It is a 1/4" shank with a 1/4"x20 thread.
  1. Torque Spec for wheel bearing and Axle Nuts
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-11-2014, 12:11 PM
  2. inner tie rod torque spec
    By jhnnyboz in forum General Tech Discussion
    Last Post: 08-08-2011, 09:01 PM
  3. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  4. Maf bolt thread size?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 12:44 AM
  5. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
