Thread: Bolt size and torque spec thread.
Results 1 to 20 of 27
Threaded View
TheOtherNick Bolt size and torque spec... 07-05-2011, 12:27 PM
gpgt98 Re: Bolt size thread 07-05-2011, 01:05 PM
Bio248 Re: Bolt size thread 07-05-2011, 05:56 PM
Kejross Re: Bolt size thread 07-09-2011, 10:04 AM
Kejross Re: Bolt size thread 07-09-2011, 10:06 AM
tdm571 Re: Bolt size thread 07-13-2011, 11:20 AM
TheOtherNick Re: Bolt size thread 07-13-2011, 08:04 PM
BillBoost37 Re: Bolt size thread 07-14-2011, 06:02 AM
flynnaz Re: Bolt size thread 08-08-2011, 08:52 PM
Phyrstorm Re: Bolt size thread 08-21-2011, 02:31 PM
dpzelenak Re: Bolt size thread 08-08-2011, 08:57 PM
flynnaz Re: Bolt size and torque spec... 08-21-2011, 11:46 PM
PurpleGuy Re: Bolt size and torque spec... 12-02-2011, 10:39 AM
BillBoost37 Re: Bolt size and torque spec... 12-02-2011, 10:49 AM
TEK310 Re: Bolt size and torque spec... 04-24-2012, 11:18 PM
Fivefingerdeathpunch Re: Bolt size and torque spec... 04-24-2012, 11:25 PM
Swiggles Re: Bolt size and torque spec... 04-27-2012, 04:52 PM
Peteman1 Re: Bolt size and torque spec... 05-02-2012, 07:07 PM
67goat Re: Bolt size and torque spec... 05-08-2012, 10:48 AM
BillBoost37 Re: Bolt size and torque spec... 05-08-2012, 11:41 AM
TEK310 Re: Bolt size and torque spec... 05-17-2012, 06:05 PM
Peteman1 Re: Bolt size and torque spec... 05-18-2012, 05:20 AM
BillBoost37 Re: Bolt size and torque spec... 05-18-2012, 06:16 AM
TEK310 Re: Bolt size and torque spec... 05-18-2012, 05:04 PM
tdm571 Re: Bolt size and torque spec... 06-04-2013, 12:00 PM
Flip97GTP Re: Bolt size and torque spec... 11-08-2014, 01:58 AM
zacaschenbach007 Re: Bolt size and torque spec... 04-18-2016, 07:12 AM
  1. #1 Bolt size and torque spec thread.
    Charles City, IA
    Feel free to add more stuff I got most of the common stuff.
    dog bone=15mm
    fender brace=13mm
    supercharger=10mm, one 13mm
    tb=10mm, 2 8mm on the support bracket for n/a cars
    egr=13mm
    egr tube bolts=3/2"
    valve cover=3/8
    alt bolts and nut= 15mm
    map bolts=10mm
    water pump pulley=8mm
    front cover and water pump 10mm and 13mm
    crank bolt=15/16
    rear cover=3/8
    oil pan 3/8
    head bolt= 5/8IIRC
    head stud nut= 1/2" 12 or 6 point
    x over nuts= 13mm
    starter bolt=15mm
    starter batter pos nut=13mm 14mm on some after market
    starter relay wire=10mm
    p/s pump=13mm
    tensioner pulley=15mm or t55 torx
    icm bracket=15mm
    cam bolt= 1 1/16" or 24mm IIRC
    torque converter bolts=18mm
    transmission bell-housing bolts=18mm
    rear engine to trans bracket bolts=13mm
    axle nut 32-36mm depending on year and axle manufacturer
    strut to knuckle bolts=21mm
    ball joint nut=18mm 19mm on some aftermarket
    strut top nuts 15mm
    front sway bar bushing clamp bolts=15mm links 13mm-15mm depending on manufacturer
    rear sway bar link nuts=18mm, 15mm on back to hold the ball
    manifold bolts 13mm
    02 sensor= 7/8"
    icm harness bolt=7mm
    Lim bolts=3/8"
    front hub bolts=1/2"
    rear hub bolts=10mm
    blower motor/blower resistor 7/32"
    small dash bolts=7mm larger ones 13-18mm
    Seat bolts=T60 torx IIRC
    headlight mounting bracket bolts=10mm(2)
    SMGPFC Two Nipple General
  1. Torque Spec for wheel bearing and Axle Nuts
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-11-2014, 12:11 PM
  2. inner tie rod torque spec
    By jhnnyboz in forum General Tech Discussion
    Last Post: 08-08-2011, 09:01 PM
  3. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  4. Maf bolt thread size?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 12:44 AM
  5. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
