Thread: Bolt size and torque spec thread.
Results 1 to 20 of 27
TheOtherNick Bolt size and torque spec... 07-05-2011, 12:27 PM
gpgt98 Re: Bolt size thread 07-05-2011, 01:05 PM
Bio248 Re: Bolt size thread 07-05-2011, 05:56 PM
Kejross Re: Bolt size thread 07-09-2011, 10:04 AM
Kejross Re: Bolt size thread 07-09-2011, 10:06 AM
tdm571 Re: Bolt size thread 07-13-2011, 11:20 AM
TheOtherNick Re: Bolt size thread 07-13-2011, 08:04 PM
BillBoost37 Re: Bolt size thread 07-14-2011, 06:02 AM
flynnaz Re: Bolt size thread 08-08-2011, 08:52 PM
Phyrstorm Re: Bolt size thread 08-21-2011, 02:31 PM
dpzelenak Re: Bolt size thread 08-08-2011, 08:57 PM
flynnaz Re: Bolt size and torque spec... 08-21-2011, 11:46 PM
PurpleGuy Re: Bolt size and torque spec... 12-02-2011, 10:39 AM
BillBoost37 Re: Bolt size and torque spec... 12-02-2011, 10:49 AM
TEK310 Re: Bolt size and torque spec... 04-24-2012, 11:18 PM
Fivefingerdeathpunch Re: Bolt size and torque spec... 04-24-2012, 11:25 PM
Swiggles Re: Bolt size and torque spec... 04-27-2012, 04:52 PM
Peteman1 Re: Bolt size and torque spec... 05-02-2012, 07:07 PM
67goat Re: Bolt size and torque spec... 05-08-2012, 10:48 AM
BillBoost37 Re: Bolt size and torque spec... 05-08-2012, 11:41 AM
TEK310 Re: Bolt size and torque spec... 05-17-2012, 06:05 PM
Peteman1 Re: Bolt size and torque spec... 05-18-2012, 05:20 AM
BillBoost37 Re: Bolt size and torque spec... 05-18-2012, 06:16 AM
TEK310 Re: Bolt size and torque spec... 05-18-2012, 05:04 PM
tdm571 Re: Bolt size and torque spec... 06-04-2013, 12:00 PM
Flip97GTP Re: Bolt size and torque spec... 11-08-2014, 01:58 AM
zacaschenbach007 Re: Bolt size and torque spec... 04-18-2016, 07:12 AM
  1. #1 Bolt size and torque spec thread.
    Charles City, IA
    Feel free to add more stuff I got most of the common stuff.
    dog bone=15mm
    fender brace=13mm
    supercharger=10mm, one 13mm
    tb=10mm, 2 8mm on the support bracket for n/a cars
    egr=13mm
    egr tube bolts=3/2"
    valve cover=3/8
    alt bolts and nut= 15mm
    map bolts=10mm
    water pump pulley=8mm
    front cover and water pump 10mm and 13mm
    crank bolt=15/16
    rear cover=3/8
    oil pan 3/8
    head bolt= 5/8IIRC
    head stud nut= 1/2" 12 or 6 point
    x over nuts= 13mm
    starter bolt=15mm
    starter batter pos nut=13mm 14mm on some after market
    starter relay wire=10mm
    p/s pump=13mm
    tensioner pulley=15mm or t55 torx
    icm bracket=15mm
    cam bolt= 1 1/16" or 24mm IIRC
    torque converter bolts=18mm
    transmission bell-housing bolts=18mm
    rear engine to trans bracket bolts=13mm
    axle nut 32-36mm depending on year and axle manufacturer
    strut to knuckle bolts=21mm
    ball joint nut=18mm 19mm on some aftermarket
    strut top nuts 15mm
    front sway bar bushing clamp bolts=15mm links 13mm-15mm depending on manufacturer
    rear sway bar link nuts=18mm, 15mm on back to hold the ball
    manifold bolts 13mm
    02 sensor= 7/8"
    icm harness bolt=7mm
    Lim bolts=3/8"
    front hub bolts=1/2"
    rear hub bolts=10mm
    blower motor/blower resistor 7/32"
    small dash bolts=7mm larger ones 13-18mm
    Seat bolts=T60 torx IIRC
    headlight mounting bracket bolts=10mm(2)
    SMGPFC Two Nipple General
  2. #2 Re: Bolt size thread
    SE Level Member gpgt98's Avatar
    Jul 2010
    Michigan
    Note: All bolts with an additional torque or degrees (*) are torque to yield bolts will will need to be replaced after removal. Also all specs are done usings a good torque wrench and torque angle meter. Not your grand pas wrench from 1944 that has never been checked since the 50's.
    A/C compressor front nuts 100 N.m (74 lb ft) .
    A/C compressor rear bolts 31 N.m (23 lb ft) .
    Camshaft Sprocket Bolt First Pass 74 lb. ft. Final Pass + 90°
    Connecting Rod Cap Bolt 20 ft.lb +50*
    crankshaft balancer bolt 150 Nm (111 ft. lbs.) + 76*
    Crankshaft Main Bearing Cap Bolt 30 ft. lbs. \ +110*
    Crankshaft Main Bearing Cap Bolt (Side) 11 ft. lbs. +45*
    Comp Cams rocker bolts 23 lb ft.
    EGR Valve37 lb. ft.
    (EGR) inlet/outlet pipe bolt (21 ft. lbs.)
    Exhaust Manifold Bolt/Nut 22 lb. ft.
    exhaust manifold pipe stud nuts 32 Nm (24 ft. lbs.)
    exhaust crossover pipe bolts and studs 18 Nm (13 ft. lbs.)
    Flywheel Bolts11 lb. ft. +50*
    front head First pass 37 lb. ft. Second pass +120* Final pass +30*(only 96-01 cars inner 4 bolts) When using head studs work your way up to 90ftlbs using the same picture, I did three passes on mine. 30-60-90
    Rear head Same specs different picture
    knock sensor 19 N.m (14 lb ft) .
    LIM 11 lb. ft. Start in the center and work your way out.
    oil pan bolts 14 Nm (125 inch lbs.)
    Oil Pump Pipe and Screen Bolt 11 ft.lb
    oil level sensor 20 Nm (15 ft. lbs.)
    Power steering pump bolts 25 ft. lbs
    Tighten the valve rocker arm bolt \ 15 Nm (11 ft. lbs.) +90*
    supercharger 17 lb. ft. Start in the center and work your way out.
    supercharger snout 15 lb.ft. Start in the center and work your way out.
    Throttle Body Bolt/Nut 89 lb. in. (7.5 lb. ft.)
    Upper plenum 89in.lb. (7.5 lb. ft.)
    Water Pump Bolt (Long) 25 ft.lb
    Water Pump Bolt (Short) 16 ft.lb
    Water Pump Bolt (SAL) 89 in.lb (7.5 lb. ft.)
    Water Pump Pulley Bolt (3.8L) 115 in.lb (9.5 lb. ft.)
    If anyone has more that they need or would like me to had post them up and I will add them. Vendor bolts/studs etc.
  3. #3 Re: Bolt size thread
  4. #4 Re: Bolt size thread
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by TheOtherNick View Post
    hub bolts=1/2"
    Fronts are, rears are different... I did one of my rears yesterday and it was 10mm(not 3/8's) for the hub with like maybe a t25(?) to get the ebrake junk off to get it out
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  5. #5 Re: Bolt size thread
    Feb 2010
    Oklahoma City, OK
    Oh and add that the egr hose bolts are 3/8's too, cause I rounded one off on the exhaust manifold of a buddies car the other day using a 10mm and some brute force. Oh how I loved drilling that one out...
  6. #6 Re: Bolt size thread
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    This thread was my idea, Nick just provided the information.
    Typically where you see 13mm above, 1/2" will fit better.
  7. #7 Re: Bolt size thread
    Charles City, IA
    Never stripped one on my many builds, just use good sockets and you will be fine.
  8. #8 Re: Bolt size thread
    Truth. Although even a good Snappy 6 pointer can occasionally round out some of the bolts. Not often though. Oh yeah..and Nick. Having air keeps the hand ratchet from twisting off the bolt head. Most won't have air.
    I absolutely don't know what I did before the 3/8" ingersol titanium came into my life.
  9. #9 Re: Bolt size thread
    Aug 2011
    Arizona
    My son just bought a 1997 Grand Prix GTP. What is the size of the Valve cover bolts? There is one missing on the front cover, and the threads are stripped. I want to use a Helicoil to fix it, but I need to know what size I need. It's a great car otherwise. Thank you for the help
  10. #10 Re: Bolt size thread
    SE Level Member Phyrstorm's Avatar
    Jun 2010
    Sioux Falls, sD
    Quote Originally Posted by flynnaz View Post
    The bolt itself is 1" long from tip to the bottom of the flange and is a 3/8" head. It has a non removable (as far as I can tell) metal washer and stem that hold the rubber grommet on it. It is a 1/4" shank with a 1/4"x20 thread.
  11. #11 Re: Bolt size thread
    does that count as common stuff
    SMGPFC Member #10
  12. #12 Re: Bolt size and torque spec thread.
    Aug 2011
    Arizona
    Thank you for the information. I went to the junk yard and picked one up for $1.75. It went on and has stayed on tight for two weeks now, no oil leak either
  13. #13 Re: Bolt size and torque spec thread.
    Never Never Land
    Not sure if anyone mentioned it but seat bolts are T50 and not T60.
  14. #14 Re: Bolt size and torque spec thread.
    I prefer to use a 15mm socket.
  15. #15 Re: Bolt size and torque spec thread.
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    by any chance does anyone have the bolt size for the CV axle, passenger side? the 5 bolts that bolt the inner joint to the trans
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  16. #16 Re: Bolt size and torque spec thread.
    I may be confusing myself here.
    but the cv just slides into the transmission, its not bolted in.
  17. #17 Re: Bolt size and torque spec thread.
    Quincy, Mass
    dog bone=15mm
    fender brace=13mm
    egr=13mm
    egr tube bolts=3/2"
    valve cover=3/8
    map bolts=10mm
    crank bolt=15/16
    rear cover=3/8
    oil pan 3/8
    head bolt= 5/8IIRC
    x over nuts= 13mm
    starter bolt=15mm
    p/s pump=13mm
    icm bracket=15mm
    strut top nuts 15mm
    manifold bolts 13mm
    02 sensor= 7/8"
    Lim bolts=3/8"
    rear hub bolts=10mm
    yes it its held onto the shaft with a c-clip. just use a pry bar and push on the back of the axle, rotate and try again if it doesnt pop right out.
    good how to: Installation of new Half-Shafts
    No more GP 04 Impala SS Indy:
  18. #18 Re: Bolt size and torque spec thread.
    May 2012
    Marion, AR
    Thanks for that entire list! Might come in handy later.
  19. #19 Re: Bolt size and torque spec thread.
    Apr 2012
    Chicago
    Awesome - I was about to look up the torque specs for the knock sensor again when I came across this! Thanks!
  20. #20 Re: Bolt size and torque spec thread.
    Enjoy your coolant shower.
  1. Torque Spec for wheel bearing and Axle Nuts
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-11-2014, 12:11 PM
  2. inner tie rod torque spec
    By jhnnyboz in forum General Tech Discussion
    Last Post: 08-08-2011, 09:01 PM
  3. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  4. Maf bolt thread size?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 12:44 AM
  5. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
