Thread: Bolt size and torque spec thread.
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #1 Re: Bolt size and torque spec thread.
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    Quote Originally Posted by TheOtherNick View Post
    Feel free to add more stuff I got most of the common stuff.
    dog bone=15mm
    fender brace=13mm
    supercharger=10mm, one 13mm
    tb=10mm, 2 8mm on the support bracket for n/a cars
    egr=13mm
    egr tube bolts=3/2"
    valve cover=3/8
    alt bolts and nut= 15mm
    map bolts=10mm
    water pump pulley=8mm
    front cover and water pump 10mm and 13mm
    crank bolt=15/16
    rear cover=3/8
    oil pan 3/8
    head bolt= 5/8IIRC
    head stud nut= 1/2" 12 or 6 point
    x over nuts= 13mm
    starter bolt=15mm
    starter batter pos nut=13mm 14mm on some after market
    starter relay wire=10mm
    p/s pump=13mm
    tensioner pulley=15mm or t55 torx
    icm bracket=15mm
    cam bolt= 1 1/16" or 24mm IIRC
    torque converter bolts=18mm
    transmission bell-housing bolts=18mm
    rear engine to trans bracket bolts=13mm
    axle nut 32-36mm depending on year and axle manufacturer
    strut to knuckle bolts=21mm
    ball joint nut=18mm 19mm on some aftermarket
    strut top nuts 15mm
    front sway bar bushing clamp bolts=15mm links 13mm-15mm depending on manufacturer
    rear sway bar link nuts=18mm, 15mm on back to hold the ball
    manifold bolts 13mm
    02 sensor= 7/8"
    icm harness bolt=7mm
    Lim bolts=3/8"
    front hub bolts=1/2"
    rear hub bolts=10mm
    blower motor/blower resistor 7/32"
    small dash bolts=7mm larger ones 13-18mm
    Seat bolts=T60 torx IIRC
    headlight mounting bracket bolts=10mm(2)
    anyone know the bolt size and length for the upper front caliper to steering knuckle bolt
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: Bolt size and torque spec thread.
    May 2012
    Marion, AR
    I am still working on this car. Got the intake all done, now it has a slight vibration, like a vaccum leak, at an idle. I found the leak, it is coming from the actuator, on the side of the supercharger. Does anyone know where to get just the canister part of it instead of paying 245.00 for the whole thing from GM? Does anyone want to buy this car for 2500?
  3. #3 Re: Bolt size and torque spec thread.
    Pete... ZZP has them.
  4. #4 Re: Bolt size and torque spec thread.
    Mar 2012
    Dallas
    no one knows the bolt size and length, that bolts the caliper bracket to the steering knuckle?
  5. #5 Re: Bolt size and torque spec thread.
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Quote Originally Posted by TEK310 View Post
    I was good using a 15mm on them.
    What size are the trailing arm bolts?
  6. #6 Re: Bolt size and torque spec thread.
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Do you all get new bolts for the LIM and the UIM, when doing a gasket replacement?
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SKĀ® 4T65E Transmission Shift Kit, 180* Thermostat
  7. #7 Re: Bolt size and torque spec thread.
    Mar 2016
    WI
    Can someone tell me what size bolt and the length of a the supercharger bolt that goes closet to the snout. (Opposite side of the oil filer side) thanks
  1. Torque Spec for wheel bearing and Axle Nuts
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-11-2014, 12:11 PM
  2. inner tie rod torque spec
    By jhnnyboz in forum General Tech Discussion
    Last Post: 08-08-2011, 09:01 PM
  3. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  4. Maf bolt thread size?
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 12:44 AM
  5. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
