Thread: Belt problems
Results 1 to 7 of 7
  1. #1 Belt problems
    Jul 2011
    Houston
    2001 Grand Prix GTP.
    Water pump was frozen, and the serpentine belt broke. I replaced the water pump and both belts. Started the car and it ran for about 10 minutes. Then the serpentine belt started to fray again. Any ideas?
  2. #2 Re: Belt problems
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Alignment? You sure the belt was seated correctly on the crank pulley? Did you check tensioner/idler pulleys?
  3. #3 Re: Belt problems
    Jul 2011
    Houston
    Thanks for the quick reply. We were thinking maybe the AC compressor was out of alignment, but we didn't have to touch that. Just the power steering pump.
  4. #4 Re: Belt problems
    Donating Users
    South Deerfield, MA
    I agree with mechguy on this one. Double check the belt to make sure you didn't miss a groove somewhere. Check the power steering pump again to make sure it is tightened all the way. If those are both good then the tensioner may be shot.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: Belt problems
    Dec 2010
    Canada
    Take off both belts and check the condition of both the pulley contact surface, and its bearing operation. Roll the idlers by hand to see how smooth they rotate, and especially check that plastic idlers grooves. How was the belt tension?
  6. #6 Re: Belt problems
    Charles City, IA
    Did you clean all the rubber off the water pump pulley when you put it back on ?
    SMGPFC Two Nipple General
  7. #7 Re: Belt problems
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Urrgh, I know how you feel right now. My buddies GTP shreds belts like CRAZY!!!, Only the outer rib gets shredded though. I've checked the alignment of pullies, replaced all idler and tensioner, put in a/c delete, and this thing STILL eats belts!!!! I want to just go ahead and replace all them, but he doesn't have the money right now to go that far.
    Good luck man, I hope you figure this out!
    For all your 3800 needs:
  1. belt squeal
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 03:10 PM
  2. belt problem
    By CHEVYBOI in forum Introductions/Noob Questions
    Last Post: 01-30-2011, 09:54 AM
  3. can you run the car without the SC belt?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:09 AM
  4. 3.4 belt
    By xsvtank in forum General Tech Discussion
    Last Post: 05-31-2010, 12:27 PM
  5. Squeaky Belt, HELP!
    By Pokey in forum General Tech Discussion
    Last Post: 05-27-2008, 08:17 AM
