Thread: Squeaky Belt, HELP!
Results 1 to 3 of 3
Pokey Squeaky Belt, HELP! 05-27-2008, 12:51 AM
VinnieGTP Re: Squeaky Belt, HELP! 05-27-2008, 01:08 AM
Zef_66 Re: Squeaky Belt, HELP! 05-27-2008, 08:17 AM
  1. #1 Squeaky Belt, HELP!
    May 2008
    I have a '97 SE with a 3800. The serpentine belt will NOT stop squeaking! It doesn't squak at idle, only when the RPMs rise.
    The belt is not worn or cracked. I have used STP belt dressing, which makes it go away momentarily, but it returns after a few minutes.
    Do I have a pulley out of allignment? Could it be a cheap or bad belt? Like I said, when I spray the belt dressing on it, the squealling goes away for a few minutes, but soon returns.
    I am going to replace the belt, and see if that helps, but I can't replace it until this weekend, because I will be working 14 hour shifts all week, and I won't have the time. I was just curious to see if someone could enlighten me as to what might be going on.
    Thanks in advance!
  2. #2 Re: Squeaky Belt, HELP!
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Could be a pulley. Do you still have the plastic ones on there?
  3. #3 Re: Squeaky Belt, HELP!
    PA
    I would say that your belt is not the problem. I would bet that you have a bad pulley, and it is a bearing squeaking.
    FWIW, I would stay away from the belt dressing stuff. Often times, this can cause a belt to slip, and while the squeaking goes away, it will wear your belt out faster. The belt dressing stuff is not your friend.
    I would suggest pulling off your belt, and spinning each pulley by hand. The idler and tensioner pulleys should spin freely, and continue to spin for only a couple seconds. If the pulley stops spinning right when you let go of it, if it makes a squeaking noise when you spin it, or if it seems like the pulley wants to spin forever, I would suggest replacing it with a new, metal one.
    But unless the belt has a lot of cracks, or sections missing from it, there is no need to replace it.
    2001 GSE
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. Drive Belt Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 05-24-2009, 05:44 PM
  3. too small of a s/c belt???
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-31-2008, 03:06 PM
  4. oil filter s-belt clearance
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 11:55 AM
  5. pulley belt from zzp
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 03:09 PM
