Thread: 98-03 Gtp vs 2004+ Gtp
Results 21 to 40 of 53
  1. #21 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    ZZ Performance
    yes and 05's have dextron IV.
    Yes the cyl heads got bigger valves in 04 and up cars
    all 04 and up trannies had the hardend clutch
    sorry i must of had a brain fart on the rods lol, they are not colored sorry guys lmfao
    i would look for an 05, almost eveything has been upgraded and no programming problems. and overall a more reliable car, less problems overall
  2. #22 Re: 98-03 Gtp vs 2004+ Gtp
    Pennsylvania
    Quote Originally Posted by wking2 View Post
    Just checked the GM service manual at gpona. All L36's (4LBB, 4LCB, 4LDB - Base, GT1, GT2) were standard transmissions. All L32's (4CBB - GTP) were HD (hardened 4th).
  3. #23 Re: 98-03 Gtp vs 2004+ Gtp
    GTX Level Member colindunn's Avatar
    Aurora, IL
    everythings been said. technically an 04+ is faster than a 97-03 from the factory. ive owned a 2001 special edition gtp coupe. i now own a 2004 comp g. love both.. something to be said about having a newer car though. still a lot of plastic in the interior but at least i dont hear it as im driving. just a newer feel to it. the gen V s/c is amazing.. theres less people with the 04+ that mod them currently. but yes, they are more expensive. more money up front. theres my input. if i had a choice, id do a comp g.
    Green Comp G. Headers. Intake. Tune. Pulley. Intercooled.
    SE fascia. Dual chrome tips. Debadge. Retrofit. Lowered.
  4. #24 Re: 98-03 Gtp vs 2004+ Gtp
    Aurora, IL
    paddle shifters, newer HUD, and xm radio are nice features too
  5. #25 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2009
    Virginia
    eye hart my comp g.
    11 is louder than 10!
  6. #26 Re: 98-03 Gtp vs 2004+ Gtp
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    I love my '05 GTP. The only thing that I would like to add to it interior-wise is a HUD. There aren't as many modded '04+ cars probably because they are, well, newer. Don't believe there are any issues with modding them though, and if you want one, you can get the 5.3 in it.
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  7. #27 Re: 98-03 Gtp vs 2004+ Gtp
    Aurora, IL
    Quote Originally Posted by hklvette View Post
    dont even start with the 5.3 in this thread.. lol
  8. #28 Re: 98-03 Gtp vs 2004+ Gtp
    utah
    I would love to DD a gxp....but never mod one
  9. #29 Re: 98-03 Gtp vs 2004+ Gtp
    Bunnell, FL
    Quote Originally Posted by boostedcompg View Post
    this
    i havent seen a heavily modded one except the cartuning and that monte in the mag
    I'm a Sex Offender
  10. #30 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    Quote Originally Posted by SlowNA06 View Post
    the hd didnt mean hardened 4th
    hd trannies were done in 97-03 cars. Hd trannies had bigger differentials and PASS AXLES
    Our clutch shafts are hardened and will resist this problem. Please note that 2003+ vehicles will already have this shaft installed.
    W Body Store
    all of them recieved the hardened 4th clutch. 04 and up cars are the better more reliable engine. hence why they are newer. now overall yes the 97-03 cars can get faster because there ligher and smaller. but all around i like the 04 and up.
  11. #31 Re: 98-03 Gtp vs 2004+ Gtp
    Pennsylvania
    I've been misinformed! Curses! Thanks for fixing that.
  12. #32 Re: 98-03 Gtp vs 2004+ Gtp
    electronic throttle control vs by wire
    intake ports are bigger
    L26's have the smallest rods of the bunch.
    How is ETC better?
    If you get a comp G you get electronic stability control which yes, is a good thing.
    But only comp G's and GXP's received that feature.
    What makes them more reliable?
    They're 90% the same.
    you'll mostly only notice the slightly increased throttle response with ETC
    How? Cable is instant, electronic relies on well, electronics. It'll be quick. But cable has no delay at all.
    exhaust valves were also slightly bigger starting in 2003
    Yet there was no horsepower increase.
    In 04...
    They deleted the U bend, installed a better blower, slightly better heads, and a better tune.
    Theres your 20 HP.
    Reasons you SHOULD buy the new cars:
    Interior.
    Less rust due to fewer years on the road.
    Better blower.
    ESC (comp G only)
    Other than that, age will ultimately show the same problems in the newer cars in due time.
  13. #33 Re: 98-03 Gtp vs 2004+ Gtp
    Aurora, IL
    personally i HATE having stability control. cant have any fun in the snow like i could with my 2001.. only cool thing it letting go of the steering wheel, and watching it make itself go back into a straight line from being sideways. lol
  14. #34 Re: 98-03 Gtp vs 2004+ Gtp
    can't you turn it off?
    Note this is required by FDC on all new vehicles now.
    It is NOT a feature to be bragged about when comparing brand new vehicles.
  15. #35 Re: 98-03 Gtp vs 2004+ Gtp
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    ZZ Performance
    ALot of fail in this post. 04+ heads dont flow any better then 97-03's
    The trans while slightly better is still a weak point.
    Pretty much what matts post covers+
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  16. #36 Re: 98-03 Gtp vs 2004+ Gtp
    i REALLY don't understand this thread.
    There are still reasons not to buy the 04+ like secondary AIR system, 200 lbs more curb weight, cost, 04/05 require a change of LCA's to upgrade sway bars.
    But quit caring so much and look at whats available in your area for what you're willing to spend.
    In the end thats what matters, what pleases you.
    Feb 2010
    tampa
    the block is the same, both engines are solid series 3 and 2, but the series 3 is totally different electrically in many ways, connectors, fuel pump, seals, abs system. etc. gm had horrible problems 90's and early 2000's with a ;ot of electrical stuff.
    but i do love the coupe look of the 97-03's
    l26's are not the smallest of the bunch, they are forged rods and much better then the l36's
  18. #38 Re: 98-03 Gtp vs 2004+ Gtp
    Pictures and peoples experience with them say otherwise.
    L26 < L36 < L67 < L32 < Swan racing.
    Feb 2010
    tampa
    and throttle by wire is mechanical and hence is not as accurate as electronically. which in turns gives u better response and economy. and so its easier for the computer to control air and fuel etc without waste more effeciently with electronics. wire fails, gets loose etc. its mechanical.
    the l26 is forged, series II is cast iron, thats a huge difference. size isnt everything.
  20. #40 Re: 98-03 Gtp vs 2004+ Gtp
    Hagerstown,Md
    NONE are forged. There powder coated
  1. 2004+ gtp fwi
    By donkason in forum General Tech Discussion
    Last Post: 09-26-2010, 12:41 PM
  2. 2004 gtp
    By krazy3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 08:41 PM
  3. 2004 gtp abs
    By justmebobg in forum Introductions/Noob Questions
    Last Post: 07-05-2009, 12:52 PM
  4. 2004 gt
    By green mountain goat in forum Introductions/Noob Questions
    Last Post: 06-16-2009, 05:43 PM
  5. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
