Thread: 98-03 Gtp vs 2004+ Gtp
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #1
    Feb 2010
    tampa
    and throttle by wire is mechanical and hence is not as accurate as electronically. which in turns gives u better response and economy. and so its easier for the computer to control air and fuel etc without waste more effeciently with electronics. wire fails, gets loose etc. its mechanical.
    Pictures and peoples experience with them say otherwise.
    L26 < L36 < L67 < L32 < Swan racing.
    the l26 is forged, series II is cast iron, thats a huge difference. size isnt everything.
  2. #2 Re: 98-03 Gtp vs 2004+ Gtp
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    NONE are forged. There powder coated
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: 98-03 Gtp vs 2004+ Gtp
    Drive by wire is the term used for electronic throttle control.
    a cable has instantaneous throttle response.
    A wire must rely on ADC's and DAC's as well as a computer to open the throttle.
    Not saying you'll notice the difference.... but I am say you wont notice the difference in throttle response.
    The fueling isn't controlled by the throttle plate, but rather the MAF and O2 sensor.
    And any fuel economy gains will be negated by the extra 200 lbs you have to lug around.
    Quote Originally Posted by 01gpgt01 View Post
    Swan racing's are....
  4. #4 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    yes but deoending on how much you open the throttle tells the computer how much fuel oxygen to let in. electronics will alwaays be more acurate then a wire. hence the car becomes more efficient.
  5. #5 Re: 98-03 Gtp vs 2004+ Gtp
    Quote Originally Posted by wking2 View Post
    Ask someone who tunes.
    Feb 2010
    tampa
    and they have the aluminum upper intake, not upgrading the older car is easier, but older cars are always easier to upgrade naturally
    what color
    Hagerstown,Md
    Powdered metal is more durable and reliable than conventional cast iron, delivering greater anticipated life. As importantly, the powdered metal rods are stiffer than the cast iron parts they replace.
    Wire you mean cable? drive by wire Vs cable just boils down to throttle response. The maf controls fueling. I fail to see any pionts here
  8. #8 Re: 98-03 Gtp vs 2004+ Gtp
    stop making 10723019823091231231 posts.
    use the edit button.
  9. #9 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    maf and throttle are all tied together is my point lol
    people will forever argue over this. You can find people, who believe in electronic and some will believe in the old way
  10. #10 Re: 98-03 Gtp vs 2004+ Gtp
    Not a valid point...the MAF isn't in the throttle body in the '04+ cars like in the '97-'03.
    Mooooooooot.
    It also has nothing to do with the throttle...as the TPS controls that.
  11. #11 Re: 98-03 Gtp vs 2004+ Gtp
  12. #12 Re: 98-03 Gtp vs 2004+ Gtp
    utah
    pretty sure only the cali cars had secondary air......
  13. #13 Re: 98-03 Gtp vs 2004+ Gtp
    Feb 2010
    tampa
    yes, just for cali cars and i think only under cold operation does it kick in.
  1. 2004+ gtp fwi
    By donkason in forum General Tech Discussion
    Last Post: 09-26-2010, 12:41 PM
  2. 2004 gtp
    By krazy3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 08:41 PM
  3. 2004 gtp abs
    By justmebobg in forum Introductions/Noob Questions
    Last Post: 07-05-2009, 12:52 PM
  4. 2004 gt
    By green mountain goat in forum Introductions/Noob Questions
    Last Post: 06-16-2009, 05:43 PM
  5. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
