buying the downpipe will save you time and money that you'd need to spend on install at a shop (unless you weld). you want a 3" downpipe, you won't lose any bottom end.
the anit-fouler trick works in most cases, but you may not even need it if you still have a cat. i never had a problem setting that code and i ran a high flow cat.
