Thread: Front wheel squeeks when wheel is straight.
Results 1 to 10 of 10
  1. #1 Front wheel squeeks when wheel is straight.
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    And goes away when I turn the wheel left. As the tire spins faster it squeeks fatser. What do you guys got on this???
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Front wheel squeeks when wheel is straight.
    wheel bearing
  3. #3 Re: Front wheel squeeks when wheel is straight.
    Oct 2008
    IL
    wheel bearing
    Those arent easy are they.... Hmmm so which side are we talkin here Id guess left but Im usually always wrong on this forum. Only if it was a Goped
  4. #4 Re: Front wheel squeeks when wheel is straight.
    no abs light yet?
    jack the front wheel up, and hold the the tire at the 12 and 6 position and see if you have any movement in the wheel, if so you found the one that's bad, but as I've found out with other car I've had, if one side is bad the other is sure to follow soon, so if you can afford to do both sides do so.
  5. #5 Re: Front wheel squeeks when wheel is straight.
    Oct 2008
    IL
    I drive about 10 miles a week. Sh** the car only has 64,xxx miles as is I bought it with 62,xxx miles 4 maybe 5 months ago. I dont think I even give the abs light a chance. Well thanks for the input guys. Is this a hard job or just a blah type of thing. Yes I will search when its not 5 sumthing in the morning lol
  6. #6 Re: Front wheel squeeks when wheel is straight.
    easy job. normally its always gunna be to the opposite side you turn, IF the sound go's away when going to the right its the left side and when turning to the left its the right side.
    Should be 5 lugs nuts, take the brake caliper off and rotor, then remove the 36mm axle nut, then the 3 bolts hold the hub/wheel bearing in. Its pretty simple. I'm syure there is a write up on the step by step prodcedure.
  7. #7 Re: Front wheel squeeks when wheel is straight.
    remember to crack the 36 mm axle nut loose before you remove the rim or jack it up, unless you have a good air gun.
  8. #8 Re: Front wheel squeeks when wheel is straight.
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    squeaky wheel gets the grease, isn't here a phrase like that?
  9. #9 Re: Front wheel squeeks when wheel is straight.
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    im having the same problem except it only squeaks when i press the brakes and only squeaks for a little bit. not sure which way to move the wheel when checking the hubs not real sure how to do it at all... my abs light is on and my trac off light is on too because of this. i know its not pads or rotors because those have only about 1.5k miles on them if that...
  10. #10 Re: Front wheel squeeks when wheel is straight.
    Oct 2008
    IL
    Thats what I figured by just looking at the bearing/hub. Thanks still car never looks good squeekin
  1. I think I have a bad front wheel bearing-help please
    By dorkfish in forum Introductions/Noob Questions
    Last Post: 04-10-2011, 05:55 PM
  2. Front Wheel bearing on an 06 GT
    By FordMan77 in forum Brakes/Suspension/Chassis
    Last Post: 01-28-2011, 06:33 PM
  3. Strange noise from front wheel
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-09-2009, 05:43 PM
  4. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
