Thread: Help with this issue please
Results 1 to 19 of 19
Guest Help with this issue please 07-02-2008, 11:13 PM
GTPJOE90 Re: Help with this issue... 07-03-2008, 12:45 AM
Guest Re: Help with this issue... 07-03-2008, 12:51 AM
FoSHO99 Re: Help with this issue... 07-03-2008, 01:21 AM
Guest Re: Help with this issue... 07-03-2008, 01:34 AM
Guest Re: Help with this issue... 07-03-2008, 12:54 AM
Reptile Re: Help with this issue... 07-03-2008, 08:41 AM
Guest Re: Help with this issue... 07-03-2008, 11:26 AM
Iron Indian Re: Help with this issue... 07-04-2008, 03:14 PM
Guest Re: Help with this issue... 07-04-2008, 04:39 PM
Guest Re: Help with this issue... 07-04-2008, 04:44 PM
UR LOSN Re: Help with this issue... 07-04-2008, 05:07 PM
13secgt Re: Help with this issue... 07-04-2008, 05:21 PM
Guest Re: Help with this issue... 07-04-2008, 05:35 PM
UR LOSN Re: Help with this issue... 07-04-2008, 05:49 PM
Guest Re: Help with this issue... 07-04-2008, 06:01 PM
Iron Indian Re: Help with this issue... 07-05-2008, 01:47 PM
Iron Indian Re: Help with this issue... 07-05-2008, 01:53 PM
Guest Re: Help with this issue... 07-05-2008, 05:00 PM
  1. #1 Re: Help with this issue please
    Moore, Oklahoma
    If your positive its oil, i'm betting its a pcv issue. Alot of people have had issues with PCV issues with Stg2 ICs. Is your IC the newer version? Did the LIM have slots machined in for PCV operation? Did you cut your S/C gaskets to mate up with the "new" PCV setup? If its an older set up, are you running an breather on the valve cover?
    As for PCV operation, I honestly can't remember, I did my check with the help of PRJ like 2 years ago and I cannot hardly remember, I know mine is working fine though. From what I REMEMBER with the oil cap off (providing you aren't already running a valve cover breather) you shouldn't feel pressure there. Also, if you hear a high pitched noise that means something is up. You could (for experament purposes of course) install your oil filler neck and rubber band and/or zip tie a sock over the hole. See if that changes anything, this will act like a home made valve cover breather if you don't already have one.
    I wish I had more memory of PCV operation, I don't though sorry. On my other cars I just deleled it all together and ran valve cover breathers. But on these 3800 motors the PCM will do funky things tuning wise without the PCV working right, thats the only reason my car still has a PCV system. Other wise i'd just have a damn breather too! LOL
    You may contact PRJ or ZZP, go over you install with them, see what they have to say. If its oil though, my only logical guess would be the PCV system, i know many have had hell with this on the stg2 ICs so its definatly something to look into, know what I mean?
    As for coolant, as long as the gasket surfaces were cleaned up good, and new orings installed I wouldn't know what would do it next. You did use brand new LIM gaskets when reinstalling correct? It may sound like I dumb question, but I know of a few people who have done this and I think its downright crazy IMO. Gaskets are cheap, replace em. Not that it matters but did you use the plastic LIM gaskets of the metal gaskets? Is there any coolant in the oil yet? Are you loosing coolant?
    Shawn W. Larsen
  2. #2 Re: Help with this issue please
    Moore, Oklahoma
    Another thing you could check too, pull out your PCV valve, shake it, make sure it rattled and ain't clogged with **** (like RTV). Hell, you may as well replace it, there cheap, like a $2? Be sure to save the o-ring. Check in the hole, make sure there ain't RTV gunked up in there. If there is, clean it out. I've heard of someone having an issue with there PCV a long time ago and it was because of WAY too much RTV to seal the S/C gaskets. Just a thought.
    Shawn W. Larsen
  3. #3 Re: Help with this issue please
    TDCRacing
    Guest
    Cool thanks for all of the help. I am running the newer intercooler from zzp now. No I dont have anything done to the lower intake manifold. I was TOLD by zzp that if I didnt do anything to the lim that i could just run a breather.
    I need to make some time for this and figure it out. The funny thing is- Is that it wasent doing it before when i installed the i/c...just after i re-installed the i/c after the cam and tranny install. The only thing different is that i put a lot of rtv. Thanks for giving me a cupple of ideas to go on...now i just have to make some time to go take care of it.
  1. Air Conditioning Issue
    By StreetChariot in forum General Tech Discussion
    Last Post: 11-17-2009, 03:53 PM
  2. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
  3. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
  4. No Acceleration issue
    By BooGTS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2008, 08:16 AM
