Thread: Help with this issue please
Results 1 to 19 of 19
  1. #1 Re: Help with this issue please
    I live here. UR LOSN's Avatar
    Rockford, IL
    something may need to be milled flat......
    did you take a straight edge to make sure there werent any gaps before throwing everything back together? something could be warped and leaking in.....
    EDIT:
    as far as the coolant (whitish smoke) all you would need is a pin hole leak........
    you said you see it more at idle? your not getting all the fuel from the injectors at that point, not like you are under boost.
  2. #2 Re: Help with this issue please
    Jul 2008
  1. Air Conditioning Issue
    By StreetChariot in forum General Tech Discussion
    Last Post: 11-17-2009, 03:53 PM
  2. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
  3. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
  4. No Acceleration issue
    By BooGTS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2008, 08:16 AM
