Thread: Wipers Stuck up
Results 1 to 7 of 7
  1. #1 Wipers Stuck up
    North Dakota
    So my friend has a 1998 gtp with 160k he used his wipers today and now they wont go down. They stay in the up position like to the farthest point of the drivers side of the windshield when they are switched off. Then he attempted to fix them by just pulling on them down and now they are in the resting position. (like when the wipers arent on between the pulses not where they should be when flipped off.)
    So what needs to be fixed when the wipers get stuck up? i read on here about a pin being bent possibly. or does somone have a link on how to fix this
  2. #2 Re: Wipers Stuck up
    when the wipers are turned off..the motor/assembly circle back and should rest on a tab to make them park. It's common for that tab to bend up over the years.
    Pull the drivers wiper and cowl. You'll see the tab once you start messing with it. See if the piece misses the tab when it reverses to try and park. Gently adjust the tab slightly and see if that doesn't fix you up.
  3. #3 Re: Wipers Stuck up
    North Dakota
    thanks got em fixed
  4. #4 Re: Wipers Stuck up
    SE Level Member tranny trouble's Avatar
    dewberry alberta canada
    ok so you got them fixed, now was the problem where bill said it would be, ? with that tab? cause mine are doing the same thing,
  5. #5 Re: Wipers Stuck up
    illinois
    yeah under the trans is a little tab with a v cut. That needs to hit the bracket to stop in the rights spot. It fixed mine for a few days then started parking upright again.
  6. #6 Re: Wipers Stuck up
    SE Level Member djs4021's Avatar
    Youngstown, Oho
    my gf's 97 gtp started resting upright at about 168k. I ended up just replacing her motor assembly. it's not too difficult to do, just getting it in and out between the weather strip of the engine compartment and the windshield can be difficult.
    01 Grand Prix GTP 8.8 MSD wires, K&N FIPK, ZZP Ceramic coated PLOG, ZZP 3'' Off-Road DP, Res Del, Borla Pro XS mufflers, Progress front sway, GMPP rear sway
    02 Bonneville SE with ZZP SSM90 kit. R.I.P
  7. #7 Re: Wipers Stuck up
    SE Level Member mnonnahs's Avatar
    Mar 2013
    Central Lake, MI
    This all should help me
  1. Windshield wipers
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-22-2011, 09:10 PM
  2. Wipers Help
    By shawnschuldt in forum General Tech Discussion
    Last Post: 12-18-2010, 12:53 AM
  3. Wipers don't work at all
    By kevinpope in forum General Tech Discussion
    Last Post: 09-12-2010, 01:10 PM
  4. wipers
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 03-11-2009, 12:58 PM
  5. how to fix wipers?
    By Dohner in forum General Tech Discussion
    Last Post: 03-07-2008, 04:35 PM
