Thread: Wipers Stuck up
Results 1 to 7 of 7
  1. #1 Re: Wipers Stuck up
    North Dakota
    thanks got em fixed
  2. #2 Re: Wipers Stuck up
    SE Level Member tranny trouble's Avatar
    dewberry alberta canada
    ok so you got them fixed, now was the problem where bill said it would be, ? with that tab? cause mine are doing the same thing,
  3. #3 Re: Wipers Stuck up
    illinois
    yeah under the trans is a little tab with a v cut. That needs to hit the bracket to stop in the rights spot. It fixed mine for a few days then started parking upright again.
  4. #4 Re: Wipers Stuck up
    SE Level Member djs4021's Avatar
    Youngstown, Oho
    my gf's 97 gtp started resting upright at about 168k. I ended up just replacing her motor assembly. it's not too difficult to do, just getting it in and out between the weather strip of the engine compartment and the windshield can be difficult.
    01 Grand Prix GTP 8.8 MSD wires, K&N FIPK, ZZP Ceramic coated PLOG, ZZP 3'' Off-Road DP, Res Del, Borla Pro XS mufflers, Progress front sway, GMPP rear sway
    02 Bonneville SE with ZZP SSM90 kit. R.I.P
  1. Windshield wipers
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-22-2011, 09:10 PM
  2. Wipers Help
    By shawnschuldt in forum General Tech Discussion
    Last Post: 12-18-2010, 12:53 AM
  3. Wipers don't work at all
    By kevinpope in forum General Tech Discussion
    Last Post: 09-12-2010, 01:10 PM
  4. wipers
    By UR LOSN in forum Visual/Body Modifications
    Last Post: 03-11-2009, 12:58 PM
  5. how to fix wipers?
    By Dohner in forum General Tech Discussion
    Last Post: 03-07-2008, 04:35 PM
