when the wipers are turned off..the motor/assembly circle back and should rest on a tab to make them park. It's common for that tab to bend up over the years.
Pull the drivers wiper and cowl. You'll see the tab once you start messing with it. See if the piece misses the tab when it reverses to try and park. Gently adjust the tab slightly and see if that doesn't fix you up.
